Results 1 to 9 of 9
Thread: My first test results with K-2006 & K-1766 Salt
    May 2012
    Las Vegas, NV
    92
    So I got tired of going to a pool store just to keep getting different numbers and being told what to buy. I returned the LaMotte 2056 ColorQ Pro 7 that I bought because it had inaccurate results each time I ran a second test. I went with the Taylor K-2006 test kit from amazon since I wanted it right away and I also got the K-1766 for testing salt water. I placed an order for the Taylor speedstir but delivery is 2 weeks or so.
    This is my first time as I'm still learning and can't wait for the speedstir as it will help greatly and will most likely give me accurate readings since I have shaky hands.
    FC: 1.4
    TCL: 0 (didn't turn pink for combine chlorine)
    PH: 8.0
    TA: 160
    CH: 250
    CYA: 30
    Salt: 4,000 (ran test 2 times, is this high)
    Pool Temp: 74
    I'm trying to play/learn the pool calculator.
    PH telling me to use muriatic acid (i have ph down).
    3.9 oz dichlor
    63 oz stabilizer
    looking for advice, please keep in mind that this is all new to me and i'm still reading and learning. Thank You.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    FC needs to be bumped up a little. Just use a little liquid chlorine to do that, then let your SWG maintain it. Ph down works, but muriatic acid is cheaper and easier. Make sure the poolmath parameters are set up with your chlorination method being swg. You do need more CYA since you are using a SWG. I would just use the pure CYA, not the dichlor. Your TCL reading should be CC. TCL is FC + CC. No need to list it. Just FC and CC. The salt isn't ridiculously high. Most swg's recommend 3000-4000.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: My first test results with K-2006 & K-1766 Salt
    Also you will save money if you use the 10m line and divide total drops by .5 on the FC test.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    If you aren't getting a high salt error on the SWG then don't worry about salt.
    Here is the Water Balance for a SWCG pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to calculate how much to add.
    CH is not that important in a vinyl pool.
    Don't worry about TA right now, it will probably come down on its own.
    The most important thing is to keep the chlorine level above minimum level for your CYA level at ALL times, Chlorine CYA Chart. When FC drops below min algae starts to grow.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you use pH down that you have on had to adjust, then pool math calls that dry acid. Weigh out the amount pool math says for Dry Acid Mix in a 5 gallon bucket until dissolved and then pour into the pool.
    Divin Dave,
    May 2012
    Las Vegas, NV
    92
    Re: My first test results with K-2006 &amp;amp;amp; K-1766 Salt
    Quote Originally Posted by n240sxguy View Post
    Thank you for your advice. What is Pure CYA?
    Quote Originally Posted by Divin Dave View Post
    Thanks, this clears it up. I was trying to figure it out on the pool calculator.
    Quote Originally Posted by pooldv View Post
    Thanks for your advice it's helpful.
    K-2006 TEST KIT
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Dichlor is chlorine and CYA. Pure CYA is usually sold as stabilizer. You had dichlor listed as something that you were going to add. I assumed it was to raise chlorine and cya. I was just saying to use just the cya and not try to add it with dichlor.
    May 2012
    Las Vegas, NV
    92
    FC: 1.4 went to 4 by using the SWG for 6hrs. I tested it twice, is this possible? Then it did what it was supposed to without adding liquid chlorine?
    CC: 0
    K-2006 TEST KIT
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Yes it is possible.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
