Thread: intex skimmer basket
    May 2015
    parlin
    1
    I have a easy set oval intex pool and having trouble with the deluxe skimmer basket. The unit keeps floating up and causing the filter to suck in air. Any suggestions on how to fix this. Try searching for it but all the related threads are old or no longer available.
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: intex skimmer basket
    Sorry I don't, but there are a lot of Intex owners with good tips around here, so hopefully one of them will have the answer.
    Welcome to TFP! Good to have you, and hope you enjoy your time here.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I too had this problem. I put a rock in mine and now it stays down where it is supposed to.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    CeltiaK's Avatar
    May 2014
    Western Mass.
    14
    Haha! I actually put a rock in mine just a couple days ago. It's never run better. I tried a few to get the right weight-to-buoyancy ratio, and now my skimmer works much MUCH better. My next pool will be a straight-sided pool with a "real" in-wall skimmer.
    Now if only the strainer grid would stop getting clogged...
    Intex UltraFrame 18'x48" - 6700 gal as filled
    Intex Sand Filter Pump 2650 gph SF70110
    Intex SWG CS8110 (copper electrode removed)
    Hayward Dyna-Skim SP1091LX
    TF100 Test Kit from Day 1!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I have the problem with my strainer grid too. Some people have cut them off. I will be installing a skimmer soon.
    http://www.troublefreepool.com/threads/75619-Adding-a-Hayward-Thru-the-Wall-Skimmer-to-Intex-Metal-Frame-Pool-(PICS!
    Lisa
