Thread: Need advice on opening a Kayak pool with frog system
    May 2015
    Hampstead, Maryland
    11
    Hi, I'm totally new to this site so I'm still trying to find things and figure out how it works. In saying that if I'm doing something wrong in this post, please tell me the correct way.
    So my question is: is it possible to open a Kayak pool without using the mineral, bam, and bac pacs? I ordered products and of course they won't arrive until after the holiday wkend. I've stumbled on some post that it sounds like it is possibly but I have no idea how to do it!!!! Do you leave an old mineral cartridge in the filter and add chlorine somehow that way? Do you leave an old bac pac in the filter while running it? Is there a way to bypass the frog portion of the filter and if so what chemicals do I need to open the pool. In the past we have used their products and haven't had any issues but it is a very expensive way to clean the pool but it's all I know!!! I'm on disability so anything I can save is important. Any advice is greatly appreciated. If you need further information or clarification on anything, please let me know. I'm hoping this is the proper way to post, so again, as a newbie, any help is appreciated!!! Thanks in advance!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Need advice on opening a Kayak pool with frog system
    Welcome to TFP!
    Someone else will have answer your questions about your frog, bac pac, etc. I don't know a thing about them.
    Here are my fave Pool School articles about how we maintain pools.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    You will need a good test kit from the Test Kit Comparison. I use the TF100 from tftestkits.net.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    You can run it without the frog pacs installed. Read through the links pooldv posted and it will all become more clear. Ask any questions you have about them in this thread.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
