Thread: Deck Coatings
    Oct 2014
    Bay Area, California
    146
    Deck Coatings
    So it looks like I'm going to be replacing my copper piping. They deck is already in poor cosmetic shape anyways. To replace the pipes they are going to cut out channels then fill them back in, so obviously it's going to look even worse.
    Any good deck coatings/overlays? I want something that will last as long as possible, and it has to be pretty thin
    Approx 15,000 gallon gunite pool, fiberglass finish. Hayward SP2302VSP, compools solar controller, 6 4x10 "Sealed Air" brand solar panels, Clean and Clear 520 cartridge filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Deck Coatings
    Are you talking about something maybe like Kool Dek?
    Essential Links:
    Oct 2014
    146
    Re: Deck Coatings
    Something like it maybe, but I don't really like the texture of kool deck
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Deck Coatings
    With a textured acrylic coating a good installer can make it look like almost any finish you like. Brick, pavers, flagstone, you name it and they can reproduce it, if they are talented enough.
    Check some of the photo gallery's on the Xcel, or Preferred Deck web sites.
    Xcel Surfaces Gallery
    http://prefdeck.com/wp-content/uploa...chure-Main.pdf
    chiefwej
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Deck Coatings
    Mine was done with a 2 colors of epoxy paint and stencil set from Sherwin Williams about 12 years ago, it is indoors, and just now starting to have some chips, however I had to cut out a 3x3 ft section of concrete a few weeks ago, and will need to patch that hole, so will probably do something new for the floor also (may wait for the next liner change which will be before next swim season)
    Here is a photo from another post a year or two ago with a temporary circulation pump rigged up
    ol[/url]
