Results 1 to 12 of 12
Thread: Pool is back up
    Jul 2014
    Oakbank, Canada
    389
    Pool is back up
    Finally had decent enough weather to re-level, install stone blocks, Gorilla pad, and foam under the pool. So far, its level, hope it stays that way. I had to put 1 1/2" shim under 1 post, not sure what happened there, but it's all good. Now just filling, then guess I will be trimming all the extra foam away and doing the landscaping around the pool. Get the pump out, and hook things up once again.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2014
    14,989
    Re: Pool is back up
    Nice pic. I can appreciate the hard work. Hope it holds-up well for you and you have a great swimming season.
    Orlando, FL
    690
    Re: Pool is back up
    Looks great!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    FunFinder's Avatar
    May 2015
    Cajun country, Louisiana
    115
    Re: Pool is back up
    Nice job! May I ask why you used foam and gorilla pad? I thought the choice was kinda one or the other. What's the advantage of combining them?
    Intex Ultra 9'x18' AG, 2800 Gph .75hp pump, 77# sand filter, Intex ECO SWG, Hayward wide mouth skimmer, KK Lil Shark vacuum, Intex magnetic light, TF-100 w/ SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Pool is back up
    Looks good man!
    Divin Dave,
    Casey's Avatar
    SW PA
    10,423
    Re: Pool is back up
    Quote Originally Posted by FunFinder View Post
    Well, one advantage could be weed barrier from gorilla pad.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Pool is back up
    Good work! Bring the heat!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool is back up
    Good job! Bet you are glad to have that sorted out.
    Essential Links:
    Jul 2014
    Oakbank, Canada
    389
    Re: Pool is back up
    I had a ton of roots I found growing under the old pool, so after removing them I wanted to ensure nothing would be able to poke up into the liner. The Gorilla pad will stop anything from growing through, and the foam does that as second protection, plus nice flat, soft bottom. Nothing quite like that little bit extra protection, and I cannot believe how soft the floor feels now.
    Took me 3 weeks of root removing, packing, wetting, packing, wetting, packing, etc until I was confident the spots I took roots from were packed tight enough again.
    Also the foam I used is only 3/4", but its the stuff we use for under poured concrete to insulate basements, so its designed for the pressures involved.
    FunFinder's Avatar
    May 2015
    115
    Re: Pool is back up
    Quote Originally Posted by DarrelB View Post
    Oh, ok, thanks for the info. I'll be setting my intex ultra up whenever it stops raining here, so I was curious. Thanks for the response. I bought landscaping fabric with a 10 year warranty against weeds growing trough it, so I hope that works. Did you get the interlocking foam or the regular edge? I was wondering if the interlocking would be worth the few dollar difference to make it easier to tape.
    FunFinder's Avatar
    May 2015
    115
    Re: Pool is back up
    Quote Originally Posted by Casey View Post
    Thanks Casey! I didn't realize you would need both.
    Jul 2014
    Oakbank, Canada
    389
    Re: Pool is back up
    I used the regular edge since that is all it came with. I had no trouble taping it together, as my wife pushed the edges while I taped.
