Thread: Is it safe to swim before conducting oclt in slam?
    May 2015
    Herndon/va
    52
    I have been slamming for 4 days and my water is finally clear yet I have not done a OCLT yet. Is it safe to swim in?
    Here are my numbers:
    FC = 3
    CC= 3
    CYA = ~20 still low
    pH = 7.3
    calcium = 300
    alkalinity=80
    Note I also added stabilizer when I started SLAM 4 days ago. FYI, my FC was about 5 this morning at 9:30 and is now a 3 after being in the sunshine all day. It is currently 5:30 and we have been out all day so that was the last time I added bleach. I added enough to bring it up to 10 this AM.
    Sand filter, plaster walls, approx. 15000 gallons.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Is it safe to swim before conducting oclt in slam?
    Its safe to swim with FC up to SLAM level and as long as you can see the bottom.
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,207
    As long as the FC is below shock and you can see the bottom of the deepest part of the pool it is safe to swim.
    I would go ahead and float CYA in a sock to get your CYA from 20 to 40.
    Support the site
