Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: CYA FC confusion
    May 2015
    pittsburgh pa
    62
    CYA FC confusion
    Reading in Pool School, ABCs of Pool chemistry, "If you have a SWG or very high levels of direct sunlight, CYA is typically kept between 70 and 80." But when I look at the Chlorine/CYA chart 70 and up have an asterisk and say not recommended.
    My pool is in direct sunlight all day long so I'm thinking i want to be in the 70-80 range for CYA, does this sound right? Am I misreading the Chlorine/CYA chart?
    11,000 gal (21' round) AG
    DE EC40
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: CYA FC confusion
    That is correct if you're using a SWG.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,186
    Generally the "full sun" folks are in Florida/Texas/Arizona. For PA, even in full sun I would start a little lower and work up if your FC loss during the day is too much. You can always add more, you gotta jump through hoops to get rid of it.
    Support the site
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    With the SWG you should probably maintain the higher CYA. It allows you to not have to run your cell as much to maintain the needed chlorine in your pool. This allows a longer cell life.
    May 2015
    pittsburgh pa
    62
    To clarify, I'm not using SWG. it was part of of piece i copied and pasted.
    I'm in PA, my pool is in direct sun all day long, and I'm trying to determine what CYA level to use. Still waiting for my Taylor K-2006 to come, but I've been using pucks for about 4 years or so, so I'm thinking it will be on the high side. Now I'm just reading everything and trying to understand.
    DE EC40
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I missed that. Tim is correct then you don't want to maintain the higher CYA. The SWG instruction difference is in my last post. Yes it requires a higher level of chlorine with higher CYA but it helps extend the life hours on the salt cell. That's why the different maintenance instructions for SWG that you see in pool
    May 2014
    Franklin, NC
    9,186
    Quote Originally Posted by 21 footer View Post
    if you test and are already on the high side and do not have an algae issue to deal with then you can stick with the higher CYA and jut chlorinate accordingly.
    Now, if your CYA is lower, say 50 stick there until it's proven you need extra CYA.
    Support the site
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    If you want a CYA number to shoot for, I'd start with 30-40 and see how it goes. Like was said, easy to add more, harder to lower!
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I get a fail for thoroughly reading today.
    Definately post test test kit results when you get that. Your CYA could indeed be high under those conditions.
    What does the pool water look like?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Even in normally "full-sun" TX, I manage CYA on the low side. As others have stated, it's much easier to add more than it is to get rid of it. Plus, I always leave a little room for vacations where I may have to use trichlor pucks temporarily.
    May 2015
    South Park, PA
    39
    Hey 21 footer, I'm in Pittsburgh too (South Hills)! After getting pool stored for the last two years, I'm draining/refilling to head for a CYA of 50 (started at ~200). Pool is crystal clear, but need to maintain higher FC because of the high CYA.
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    May 2015
    pittsburgh pa
    62
    Quote Originally Posted by scott39 View Post
    How much water did you have to drain to get down to 50, all of it?
    DE EC40
    38,305
    CYA will drop by the same % as the amount of water you drain. 200 to 50 would require replacing 75% of the water.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    CYA doesnt occur naturally in water. So draining the whole pool would result in a CYA of 0.
    Think in percentages.
    If your CYA is 100 and your target is 50, drain half
    If its 100 and your target is 40, drain 60%
    Divin Dave,
    May 2015
    pittsburgh pa
    62
    finally got my test kit. here are my numbers
    FC 0
    CC 0
    TA 160
    PH 7.4
    CYA 70
    TA seems pretty high, i may test again, but right now i'm draining some water
    and ps, I'm crystal clear.
    DE EC40
    May 2015
    pittsburgh pa
    62
    Thing that ticks me off is my ta was around 80 and pool store had me raise it
    DE EC40
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Now you need some chlorine
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You can lower it once you have everything else in order. I can imagine your frustration though. Many of us listened to the pool store prior to coming to TFP.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    pittsburgh pa
    62
    Quote Originally Posted by Azgirl71 View Post
    I returned 160.00 worth of their garbage today to them (phos out, algecide, shock) so at least I have that
    I figure if i can get the CYA to around 60 i can work with that for this year. Then I plan on replacing my skimmer next (or close of this season), and I'll have to do a big drain then.
    Putting about 6 inches of water back in now then will slam it.
    DE EC40
  20. Back To Top    #20
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Nice! Yes, CYA of 60 is manageable for sure. Good plan.
