Thread: swg what is 1.45lbs
    May 2015
    frankfort il
    22
    swg what is 1.45lbs
    salt water generators say produces 1.45 lbs per day what is that equal to in lets say 12.5% bleach
    inground pool 30000 gals vinly liner coverstar automatic cover
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    swg what is 1.45lbs
    1lb is roughly a gallon of 12% based on what I've read. That's running at 100% output 24/7.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Re: swg what is 1.45lbs
    SWGs are rated in the equivalent weight of chlorine gas they can produce. You can use PoolMath to convert that to something easier to relate to, or just use n240sxguy's rule of thumb.
