Results 1 to 10 of 10
Thread: Pump Recommendations for Draining Pool
    May 2015
    Moorpark, CA
    171
    Since my CYA is around 240, I need to drain and refill the pool. Some people have recommended doing multiple 20% drain and refills to prevent popup or structural damage to the pool. I also have been told to avoid drying out the plaster. A 20% drain will also allow me to use the pool water to irrigate my lawn and yard each time instead of the sprinklers, without completely flooding it.
    I can rent a submersible pump for $40 a day at Home Depot, but since I will need to do six 20% drains, that would be $240. I might as well buy a pump. I am new to this, so am not sure what specifications and models I should look for. Any recommendations for a decent quality pump would be appreciated. I want to avoid the problem another member had when the pump leaked oil into his pool.
    Michael
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump Recommendations for Draining Pool
    You can buy a cheap submersible pump from harbor freight for around $60, but if you want to get much flow out of it to run sprinklers you may need a bigger one. Alternatively just add a hose bib tap downstream from your pool pump and use it to water the yard and refill as you go draining down just a little each time.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    http://www.amazon.com/Superior-Pump-...ef=pd_sxp_f_pt
    You could get something like that one. I have the 1/5hp one. It pumps 5gpm by the time it pushes through the hose.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    Moorpark, CA
    171
    Thanks for the ideas guys!
    Would it be possible (or recommended) to drain my pool with the pool pump by putting the filter in back flush mode? I could probably attach a hose to the back flush outlet.
    Michael
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It is hard to say without knowing what kind of filter you have, to make it easier when asking such things, please put your pool equipment in your signature line. http://www.troublefreepool.com/conte...efore-you-post
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by Isaac-1 View Post
    I updated my signature.
    I also have a post here which shows a picture of the filter.
    Can Anyone Identify This Filter
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I don't see any easy way with the plumbing that is visible in the photo
    May 2015
    Moorpark, CA
    171
    It can't dump out the backwash pipe at the bottom of the filter?
    Michael
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You can but I don't know the design of that DE filter and if extended backwashing would harm the grids, I guess you could remove the grids then it would probably be safe.
    May 2015
    Moorpark, CA
    171
    That makes sense. Thanks Isaac! I appreciate the help.
    Michael
