Results 1 to 12 of 12
Thread: What if everything checks out but SWG doesn't generate chlorine?
    May 2011
    PA
    38
    Question What if everything checks out but SWG doesn't generate chlorine?
    I have a Hayward Aqua-Rite with a T-15 cell in a 25,000 gallon pool. It has worked great for 3 years. This year I opened it up and it was giving me the CIL-failure, but after replacing the part the controller is indicating everything in order. The cell is perfectly clean and clear and I've had multiple water tests done at Leslie's that show all chemistry in specs.
    Now I've been running the SWG for 48-hours straight set to super-chlorinate (i.e., 100% on) but my chlorine is still near zero. What else could be going wrong if the cell is clean, the water is good, and the controller thinks everything is fine?
    For reference, chemistry is:
    • Salt: 3400ppm
    • pH 7.2
    • CYA: 70ppm
    • Total Alkalinity: 80ppm
    • Ca Hardness: 320ppm
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: What if everything checks out but SWG doesn't generate chlorine?
    The cell may have reached the end of its life
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    30,424
    If your cell is producing chlorine, it may be consumed by algae in your pool that you can't see.
    Take your OTO chlorine test (thew one in the blue plastic box) and fill it with water coming directly out of the return. That sample should return a pretty high level of chlorine when you put in the 5 drops of R-0600.
    Then you will know at least that you are producing chlorine. Let us know what the results are.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Have you had the cell tested? Could be a dead cell. Or if the cell is working something is eating up the CL.
    I'd suggest you do a overnight chlorine loss test to see if something is eating it up. Use plain bleach to bring your CL up. Test CL level after sundown, then again the next morning before the sun hits the pool. If you have more than 1ppm loss overnight, then something in the pool is eating CL and you'll need to go through the SLAM process.
    Btw, even if your chems are "good" (pool store test results really aren't trusted here, and good according to the store isn't necessarily what's considered good here) and the water is clear, you still could have the start of an algae bloom eating up your CL.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jun 2011
    Long Beach, CA
    2,790
    Leslie's might have a tester to check the cell if it is working.
    Also, you can get a sample of water after the SWG, unscrew the cell and fill your test vial when it leaks out. Make sure the cell is showing it is generating when you take the sample. It should show that some chlorine is in the water.
    You might have nascent algae that is consuming the FC if the cell is working. The cell just can't make enough chlorine to get ahead of it and a SLAM will be needed if this is the case.
    You need to bump up the FC level with liquid chlorine in the meantime until you determine if the cell is still working.
    Please post the diagnostic numbers when you scroll through the diagnostics. What is the water temp?
    May 2011
    PA
    38
    This was a good idea: I always test water taken from the far end of the pool (near skimmers, away from returns). When did the OTO test on a sample straight from the return I got 5ppm!
    Follow-up question: if I'm losing chlorine at this rate should I add algaecide? (Note also I have had a solar cover on the pool, which I assume reduces chlorine loss to sunlight.)
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Quote Originally Posted by dbooksta View Post
    I would not add algaecide. You need to do the SLAM process.
    http://www.troublefreepool.com/conte...tain-shockingl
    May 2011
    PA
    38
    Quote Originally Posted by ping View Post
    Water temp is 80F. SWG controller is reporting 25.7V and 6.3A through the cell.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That's making chlorine. Something is just eating it all. Slam away.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    30,424
    SLAM your pool. There is a SLAM article in Pool School that must be followed precisely. I would suggest you first read "The ABC's of Pool Water Chemistry" up in Pool School.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here is the official process for SLAMing Your Pool
    Here are some intro Pool School articles
    TFPC for Beginners
    Here is the Water Balance for a SWCG pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    Don't know why the fonts are weird. It's an upgrade
    Hemess's Avatar
    Norman, OK
    95
    Sounds like my cell...last year it limped along, kept thinking it was just me, or I was doing something wrong...I didn't want it to be the SWG (mine is a Pentair IC40).
    Broke down this year (no chlorine unless I add it) and replaced it, I have chlorine coming out the gadzoo now....
    Probably the cell.
    28,000 IG, gunite, IntelliChlor IC40 SWG with SPA,
    Intellichlor/VS Pentair
    Norman, OK
