Thread: Chlorine test
    May 2015
    TN
    312
    Chlorine test
    Is there a better way to test for FC when you are having to run a higher FC level due to your CYA being up? I got my CYA down to 100 but don't have the time to drain in the next few days. So, I am having to put so many drops in t9 test. Like 40ish.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Chlorine test
    Dilute your sample 1 part tap water to 1 part pool water and each drop counts as 1 FC. Definite loss in accompanying accuracy though.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Chlorine test
    That is the only way to test that I am aware of.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
