Thread: Major Liner issues
    Major Liner issues
    Hello!
    I've never had this problem before but I uncovererd the pool today and saw this...
    Major Liner drop and creasing!
    The liner was replaced shortly before I bought the house 6 years ago and I've never had any issue with it.
    I have a whole whole lot of water that travels through my yard but I have added major drainage in the last couple years. However this was a particularly wet year so I don't know if there was a floating liner issue or what.
    I guess the big question here is what do I do? replace or drain and try to repair?
    Thanks in advance!
    20,000 Gallon Vinyl Liner Pool
    Built in 1966
    1 HP Pentair SuperFlo pump
    Ancient Hi-perm Fabric Cartridge Filter
    30,431
    Re: Major Liner issues
    Almost surely liner float.
    You will be able to probably reattach the liner if you drain a lot of water but I doubt you will ever get all the wrinkles out......hard to say but worth a try.
    I think you are probably in for a new liner and then working on your drainage some more to keep it from happening again.
    Thanks. That's what I thought. Really wet winter here this year - not sure how to fix drainage more than I already have.
    So either way it's time to start draining the water out right?
    Built in 1966
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Often times with vinyl liner, if the water gets above the bead where it hangs in the track, water will seep down behind the liner and float it. Not saying thats what happened, but its a possibility.
    Divin Dave,
    I don't think that's the case, I was filling it with the cover on but had it about 6" below where it is now until yesterday.
    Built in 1966
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    We had something similar happen some years ago when we had two back to back bad noreasters come through.
    The place we bought the pool from was able to fix it, but we didn't have the wrinkles you have in the bottom of the pool.
    the neighbor behind us also had his liner float, but he just reattached it and left the wrinkles alone. It doesn't look great, but it's perfectly functional.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
