Thread: TA level importance
    jccams's Avatar
    Dexter, MI
    95
    TA level importance
    I have a manually chlorinated pool and TA -70, PH -7.5 and has been for a week. Question is since it is much easier to raise TA than lower it is there any reason other than PH buffering for me to raise it to the 100-120 recommended range. My PH seems to be holding fine with TA at 70.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TA level importance
    Your TA is fine where it is. Dont raise it.
    http://www.troublefreepool.com/conte...mmended-levels
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    jccams's Avatar
    Dexter, MI
    95
    Thank-you. My numbers of 100-120 came from the laminated card in my TF test kit. Should have looked on here for the chart.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Happy to help.
    Lisa
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    TA isnt really something that you can put your finger on and say "it should be this", especially in a vinyl pool.
    It buffers the pH fluctuatin.
    A lot of things work into the chemistry of rising pH and a recommendation is just that. What really matters is that your pH is stable. If that means TA is 70, then there is nothing wrong with that.
    FWIW, mine is about 50 and my pH is rock solid. I havent had to lower pH in about a year.
    Divin Dave,
