Thread: Beginner getting it balanced
    Jun 2014
    chicago
    9
    Hi Everyone,This is my second year with the pool up and running and this year I'm getting serious about getting everything balanced very well. Last year everything was clear and using test strips (ugg) everything seemed to be pretty good with great clarity and no problems. We had very high iron levels when we first filled (turned pool green) but 2 days of filtering and washing filter removed that. My primary concerns are protecting the heat exchanger on heater and general equipment and keeping it safe. Pool at the current water level is 7500-7600 gallons.
    Here's my readouts (tested a few times to make sure results were consistent). Pool is generally kept heated from 75-92f, and covered 100% of the time except when in use (5-10 hours a week). Using Triclor pucks and shocking occasionally (probably need better guidance on this).
    PH 7.2 -Does this need to be raised? Whats the best method?
    FC 14 -Is this high enough for CYA level or should it be reduced? I've removed pucks from the floater and closed it up.
    CC 0
    TC 14
    TA 150 -I know this seems high (whats the best way to deal with this?)
    CYA -60 -This seems high. Is it a real concern? Seems water replacement is the only real solution. Pool is in sunlight 50% of day but always covered.
    CH 420 -Also seems high. Don't want it to damage vinyl liner.
    Thanks for your help getting this balanced!
    7500 Gallon AG, Hayward Voyager Pro filter, 2hp Hayward (AOsmith) pump, Hayward H100 heater, Installed 4/14, TF100 Kit, city water with high iron levels
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Beginner getting it balanced
    Your numbers look good. PH will likely rise on its own with TA on the high side. CYA is fine ( a little high, but shouldn't hurt anything) CH does not really affect vinyl so you are good there.
    I want to note that you should probably let FC drop below 10. The PH may not be accurate above 10 FC. I would retest once FC is below 10. I keep my FC 7/8 range.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree, not bad at all. Just focus on pH and you can work TA down later if you like, but where you are now really isn't a concern. AZgirl has you right.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Agree that TA isn't terrible and it will likely come down on its own. If you want to slowly lower TA here is how, Lowering Total Alkalinity
