Results 1 to 7 of 7
Thread: Do I need to SLAM??
    Aug 2014
    st peters mo
    19
    Do I need to SLAM??
    I just opened the pool and am not sure if I should SLAM. It has been open for a few weeks now, and water is very clear, but there a small spots here and there where green algae is starting to grow on the bottom. I have been brushing it and vacuuming and it seems to move around a little. I have been maintaining FC around 4-7. (pH is 7.8, TA is 70, CYA is 50-60). I thought about doing the overnight test for FC...I tested about 5 pm and got a reading of 7. pump and swg shut down around 8 pm and I tested again just now (pump and swg have not yet started for the day) and got a reading of around 5.5.
    So would SLAMing help here, or should I just continue keeping levels in range and chasing the little bits of algae? I attached some pics, but it is barely visible in them. It really is a small amount, but I've not had this before and am a bit annoyed with it.
    Thanks!
    31K gal IG vinyl | Pentair Sand Dollar filter | Pentair Intelliflow VS pump | Pentair IC40 SWG | Aquacomfort H/C heatpump | Pentair Easy Touch controller | Dolphin M4 cleaner | TF 100 test kit
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Do I need to SLAM??
    Yes SLAM whenever you get algae. Keep the pump running 24/7 and raise your FC to slam level. It should go quick.
    Sorry I missed the ph. Add acid and bring it down for the slam.
    Your slam level is 24
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would SLAM it if it were mine. It may be pretty easy with this one, but I'd want to get it eliminated.
    Welcome to the forum!
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I agree with Partick.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2014
    Cincinnati / OHIO
    14
    FC 2.5
    CC .5
    TA 200
    PH 7.5
    OTCL 1
    My pool is nearly crystal clear but still a bit cloudy and I just got done slamming after a very cloudy pool but didn't wait until crystal clear. The pressure is only 4% over clean and was wondering if I should be doing anything else. Vinyl liner pool. 21500 gallons.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You just need to re start, and follow your SLAM through to the very end. Make sure that all criteria are met for completion, no short cuts.
    Essential Links:
    Jul 2014
    Cincinnati / OHIO
    14
    Can you leave an auto cover on while slamming this way the sun doesn't affect the chlorine?
