Thread: In-pool spa seat jet
    May 2015
    moyock,nc
    1
    The jets in the spa seats of the pool are putting out too much water at a pretty good pressure. I've tried turning the adjustment nozzles on top, positioning them all the way closed, and still the jets won't cut off. I believe this is effecting the way the polaris is running because too much pressure is being sent through the jets, lessening the pressure the polaris needs to run. What can I do? Do I need to replace the jets? The pool is about 12 years old.
    18x36 IG
    19500 gal.
    Hayward chlorine pump/filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: In-pool spa seat jet
    Welcome to TFP!
    Is there a valve by the pool equipment that controls water flow to the jets, returns and cleaner? There usually is a valve and you can turn it to send more or less water to different places.
