Results 1 to 11 of 11
Thread: Does Increasing CYA(Stabalizer) also increase your ALKALINITY Readings?
    Jul 2010
    North Bergen, NJ
    172
    Folks, sorry about this rookie question but Im learning all I can in your Pool School ABC sections....
    So recently I have been trying to even out my water chemistry to the appropriate Salt Water Vinyl pool recommendations based on the SWG Water guide. Based on test kit readings, I have Low CYA (almost 0) and High Alkalinity at 160 (which I've recently lowered from 180 using some techniques recommended here)
    But now the more I read and the more I learn, Im kinda confused at a few things and how I should overall attack balancing the numbers ultimately. Is CYA a certain percentage of your Total Alkalinity?....if so, by trying to increase the CYA to normal levels, am I just now also adding to the higher Total Alkalinity in my pool?
    Which setting should I start with first?
    Do I get the CYA normal at 40ppm? (is 40 best for SWG?)
    Do I then attack the high Alkalinity and get it down to 80ppm?....then work on rebalancing my PH up again to 7.4-7.6 by aeration?
    Should I worry at all about my Free Chlorine level if its over 5ppm? or does the SWG take of all that automatically?
    Thanks...if anyone cares to help me thru this a little, I'd be most appreciative. I kinda understand it but just need a little walk thru at a hi level
    Design 14x26 (10,000 gal) in ground vinyl pool, 2 Wide Mouth Skimmers, 3 Returns
    Equip 3.0 HP Pentair VS pump motor, 48 FNS Plus DE filter, IC20 SWCG, 400Btu NG Heater
    Extras Easy Touch Automation, Pentair LED Lite, Kreepy Krawl Racer pressure cleaner
    Water pH 7.5, Total Alk 90, Free Cl 4.5, Combine Cl 0.25, CYA 65, CH 275, Salt 4100ppm, Borates (Boric Acid) 50ppm
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    CYA doesn't increase your TA. CYA should be 70-80 with a SWG. FC will be relative to your CYA level. Check the chart in pool school to verify where you need it. Your SWG will make chlorine based on pump run time and the % output you have it set at. Continue using acid and aerating to lower your TA.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2010
    North Bergen, NJ
    172
    Re: Does Increasing CYA(Stabalizer) also increase your ALKALINITY Readings?
    Is it safe to swim this weekend if my numbers arent where they should be but the water is clear?
    Im still currently at TA of approx 120-130ppm and my PH is around 6.8 or maybe even under (my poolmaster solution kit only goes down to PH 6.8 readings) but Im aerating my 10,000 pool by pointing the returns up to the surface and have my Pentair VS 3HP pump running at 3100RPM. Btw, how long should aerating take like this to get some pH up to at least 7.2?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    You could add a little Twenty Mule Team Borax to raise the PH without raising the TA by too much. Aerating takes a while on my pool.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Get some CYA dissolving in a sock in the skimmer, the TA doesn't hurt anybody, add a little borax to bump the ph up, and have fun swimming. The scary thing is all the thousands of people who will be in a pool this weekend who have no clue about whether it is safe or not.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    People tend to obsess over TA too much, it really is the last step in fine tuning a pool and there should be no rush getting it done. I would add some Borax to raise pH and swim then worry about the TA at some point later.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Here is how to gradually lower TA, Lowering Total Alkalinity. No hurry.
    Also, here is the Water Balance for SWCG pools
    Jul 2010
    North Bergen, NJ
    172
    so if I understand the order of importance it would be:
    Get CYA set properly first?
    Get pH set properly 2nd?
    Get Alkalinity set later on...its not a high priority in comparison to the first 2?
    Where would Chlorine fall into this?...or should I not worry since I have a SWG and it should be automating the chlorine properly?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Chlorine is #1, and directly related to #2. Then ph, then TA and CH. You need to keep an eye on your FC readings to make sure your SWG is making enough. That's also related to your CYA because of you don't have enough, the sun will burn it off.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In your case I would say CH dead last, it is NOT needed by vinyl pools, but may be needed for some equipment warranties, particularly heaters, even though CH should have no effect heaters, some of the manufacturers seem to just copy an industry standard chemicals level chart into their warranty.
    DFW, TX
    24,514
    You kind of have the right idea.
    Chlorine must always be above the minimum level for your CYA level or algae will grow. Chlorine CYA Chart
    You have to have CYA in the water to keep the sun from burning off your CYA too fast, and to make the pool more comfortable for swimmers.
    PH needs to be maintained between 7.2 and 7.8 at all times.
    TA needs to be monitored and managed, it often will correct itself.
    CH needs to be monitored and managed in certain situations where there is hard or soft water.
    Here is more info, ABC's of Pool Water Chemistry
