Thread: 7 k or 15 k saltwater system???
    Hello all...wanted to upgrade to a saltwater system and we have the 14 ft intex ultra frame pool around 3,700 gallons...there's 2 diff systems the 7,000 one or 15,000 one....both are the same price just wanted to know if I bought the 15,000 would it be a bad idea as next year ill have a bigger pool (will buy us a new one when they go on clearance this year) just wanted to ask the pros before buying....thank you
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: 7 k or 15 k saltwater system???
    I would get the bigger one. You may end up having to cut your pump time back some depending on how adjustable the output settings are on those, but it would be the right size for your new pool next year.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    go with the biggre one if they're the same price
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    +1 on bigger!
