Results 1 to 14 of 14
Thread: Adding dogs, rain and dirt / pool not so good to start this season
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Question Adding dogs, rain and dirt / pool not so good to start this season
    Hello all,
    Sorry for what will be a long OP but after such a good first year on the BBB system, a few monkey wrenches have been thrown into our system this year and I'm sort of struggling to keep up. As a brief review, after having the best looking water we ever had last year, we ran our system through the colder weather this winter (never shutting the system down for the winter but running only on days where cold might be a problem). No problems there at all.
    I was surprised and pleased how clean our water stayed all winter (despite really doing nothing to it the entire winter). However, as the calendar turned to April and into May, we have had one of the wettest springs on record in Arkansas. Before we received any meaningful amount of warm weather to really get the grass growing, we have had a six week period where almost all of our soil has been full saturated.
    There is one other new factor I should note here - the good water quality of April (seen in the second photo) has given way to a dirtier version courtesy of our two lab puppies (seen in the first photo).
    Young puppies + constantly wet soil + puppies running rampant around yard = lots of dirt in the pool.
    I've been reading previous threads here about dogs and pools and I know one area where I have missed the boat has to do with a skimmer sock to trap the dog hair. As a result, I have to believe my sand filter may have a good bit of dog hair trapped within. Additionally, I've also not been running my Dolphin pool cleaner nearly enough. So I know I have two action items right there.
    My test numbers still look pretty good but the pool visually looks dirty thanks to all of the dirt brought in by the two labs. My CYA was low when I did my first test of the year recently and I am working to bring that number up.
    With respect to controlling (limiting) the dirt, we'll need some help from Mother Nature, and more cleaning.
    My question has to do with the sand filter. Can I clean the sand (using Baquacil Sand Filter Cleaner) - is this stuff strong enough to dissolve the dog hair in the sand filter - or should I change the sand?
    Either way, I am getting a sock to put on both skimmer inlets but is there any other advice anyone can offer when dealing with a lot of dirt and dog hair in a pool?
    Thanks all!
    20K gal, IG vinyl, Waterfall on 2nd pump (1HP US Motor), Dolphin cleaning system, Central Arkansas, installed 1999
    2 Haywood Super Pumps, 1HP (main and waterfall pumps), Purex Triton II (TR 60) Sand Filter (replaced original 2016)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Adding dogs, rain and dirt / pool not so good to start this season
    Are you running a Baqua Pool? The answer to that will direct my answers to your other questions
    Support the site
    Dog hair will backwash out of the filter just fine. Hair can require more frequent backwashing, or in extreme cases clog up the pump, but shouldn't cause any other issues.
    There is hardly ever any need to use a chemical sand cleaner. They are meant for a rather uncommon situation involving large quantities of oil, for example suntan lotion, getting into the filter. Likewise, there is practically never any reason to replace the sand. Sand will last forever as long as it doesn't accumulate calcium scaling in the filter and turn to rock.
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Tim,
    I came over from the dark side last year - converting from a Baquacil pool to the TFP method. I still have a few items left from my dark days and one of those is a Baquacil Filter Cleaner.
    Jason,
    Thanks for that info though. I was hoping my sand would last longer - glad to hear it should!
    One follow up question if I could - under the TFP method, how often should I change my sand?
    What should I look for as a cue to change my sand?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,499
    Sand will last forever as long as it doesn't accumulate calcium scaling in the filter and turn to rock. If you cannot perform the deep cleaning process, http://www.troublefreepool.com/threa...-a-Sand-Filter
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Quote Originally Posted by pooldv View Post
    Thanks for that thought, Pooldv. I just completed that process and I did get a lot of crud from the filter. It will be interesting to see how this looks in a few hours.
    DFW, TX
    24,499
    Love the pic of the dog jumping into the pool!
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by bbodb1 View Post
    great! Let us know how it works.
    Support the site
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Tim5055 - the cleaning made a definite improvement today. I couldn't get a follow up pic because every time I started outside today, it rained again (aarrrggghhh!) but I will put one up as soon as the weather allows. As an aside, turning the pump back on after the deep cleaning produced a flow rate I had not seen in some time!
    Thanks Pooldv - she is that happy when it comes to pool time!
    Here another version of that photo...
    DFW, TX
    24,499
    Nice! That is one happy dog!
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    While I'm going to fight a continuous battle with dirt in the pool (courtesy of the labs), deep cleaning the pool filter made a world of difference.
    Here we are today:
    DFW, TX
    24,499
    Nice! Is it muddy feet? What about getting a kiddie pool from the sporting goods store, I saw on less than 3' diameter thet might be good to dunk the dogs in first, if you can catch them!
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    We've tried that approach, Pooldv - only to watch them sprint right past the kiddie poll and dive right into the big pool.....
    However, a little training might (at least) get them to use the kiddie pool (on occasion) prior to getting in.....it sure can't hurt!
    Jun 2014
    15,187
    I have 7 dogs. But mostly it's my German Sheppard who loves the water resulting in a good amount of hair in the pool. I use a skimmer sock which catches most of it before it gets to my pump basket or pump. Some people use a nylon stocking. I use a 1-gal paint strainer net from Home Depot. It catches a lot of junk before getting past the skimmer. As for the dirt and mud - we're soaked in S. Texas as well. The dogs do bring-in a bit or dirt, but so do my teenage boys.
