Results 1 to 15 of 15
Thread: Thinking about installing an IC40
    Jul 2013
    Long Island, NY
    14
    Hi folks,
    First, some background. I acquired a house with a pool 2 seasons ago ...struggled though one and a half of them to keep the pool reasonably algae free. Then, thankfully, I found this site and adopted TFP methods. And WOW!! is all I can say. I learned what "sparkling water" really meant. That felt great but lugging jugs of bleach, not so much. So, this year I'm thinking of adding a SWG. An IC40 with EasyTouch controller, to automate with my Intelliflow VS pump, to be exact. Is the IC40 a good size for 21k gallons?
    As I'm in the process of planning the installation (have to rework my pvc lines anyway) and was wondering if 12-18 inches of straight pipe before the inlet is really necessary. Any opinions or experiences?
    Thanks all.
    21K gallon, IG vinyl, Intelliflo VS, IC40, EasyTouch, Pentair FNS+ DE filter, Dolphin Oasis Z5
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,450
    Re: Thinking about installing an IC40
    I installed IC40's on both of my daughter's pools, with the suggested 18" of straight pipe and the pool builder installed my IC40 with about a 1/16th of an inch of straight pipe. All three units are working fine and I can't see any performance differences between them. The responses I have seen before all say the 18" is the suggested best set up but is not an absolute requirement.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    The IC 40 would be perfect fit for your pool and wil integrate nicely with your Easy Touch and Intelliflo.
    You will love a SWG when it gets fired up. But it will also make you lazy! haha!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Love my IC40, not much straight pipe in front of mine. Still working great, about to start season 4. Pics in my build in my sig.
    Jul 2013
    Long Island, NY
    14
    Thanks for the great feedback guys. I'll try to get some runway in there but won't kill myself.
    Definitely looking forward to getting lazy but somehow I don't think that will ever happen.
    ffournier's Avatar
    Apr 2015
    Houston Texas
    43
    The IC40 will do the trick and then some. I have one and on my 25K gallon pool. Anything past 40% and I start getting to much chlorine, even in the hottest summers.
    25K gal saltwater gunite and Pebble Tech plus built in spa. Features-Weeping rock wall, and fountains. All Pentair equipment. Main pump- Intelliflo 4/160. Feature pump- Intelliflo 2hp single speed. Aux cleaner pump-Pentair 1hp. DE filter, Pentair heater, Glacier GCP210 pool chiller.
    Mar 2007
    Murrieta, CA
    215
    I have an IC40 and an Easytouch, and I like the control that I get with the combo.
    However, the IC40 can be somewhat expensive to maintain. It's anecdotal, but there are many reports of failed cells. I myself wnt through two bad cells in about 4 years. After switching to tablets for a few years, I spent the $500 for another one. My third cell is just starting its third season, but I've had my issues with it.
    I'm sure all salt systems have their fair share of failures. What you might want to consider is the cost of replacement cells, as I think the IC40s are one of the most costly.
    Also, while you may not need to lug gallons of bleach any more, you may need to get accustomed to lugging gallons of Muriatic Acid. It probably depends somewhat on your water supply, but SWG's do tend to cause pH to rise.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Jul 2013
    Long Island, NY
    14
    Quote Originally Posted by peterl1365 View Post
    Good feedback. Thanks. I did as much research as possible on reliability and it seems all cells have their weak points. The cost of IC40 cells is one of their drawbacks. But, integration with my Intellifow pump is a big plus for me. I haven't heard much about pH issues. Guess there's no way to predict that?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    You'll learn how fast it rises with a little time. Some people don't have much of a ph rise at all. Others have quite a bit. When running my previous swg, I would add acid about once a week to drop from 7.8 to 7.5. I just installed a new swg, and I haven't had it long enough for it to raise the ph yet.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2014
    Mesa AZ
    54
    If you do have pH issues you can put in an intelliph system. Works great with ic40 and I love mine.
    May 2015
    kingston springs, tn
    102
    Put in my Intelliclor IC40 a couple of days ago. Took a little bit to get the salt right but I wanted to be careful and not over do it. Seems to be working great. I haven't had it long enough for a valid opinion but so far so goo. I love it!!
    Mar 2012
    Cincinnati, OH
    55
    Sorry to hijack this thread, but it seems to make more sense than to start another thread regarding the same question. I went into a local Pentair dealer today to inquire about the cost of having a Clean & Clear Plus filter installed. Was quoted $1,300 for a 4020. I can only assume that is for the CCP420. Anyway, that didn't seem like a bad price. Then they talked to me about a IC40 and all the benefits. They want $1,800 to install. That seemed like a lot to me. I am pretty handy with plumbing and electric, so am wondering if I shouldn't just purchase everything on-line and install myself. Looking to lessen the daily maintenance on my pool.
    18k, 2001 Ft. Wayne 18'x36' oval sport pool with polymer walls, IG, vinyl, 3.5' at ends and 5' in center, Pentair 1 1/2 hp 2-speed pump (new in 2014), Pentair Clean and Clear Plus Cartridge Filter (new in 2015), Pentair IntelliChlor IC40 (new in 2016), new Raypak RP2100 propane heater (installed 4/2013), Mayfair Dolphin Supreme 4 cleaner, 3 jets, 1 floor drain, 1 Polaris jet (never used), 2 skimmers, new Garrett liner (installed 4/2012)
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If you have ever installed a light switch, and understood what you were actually doing, and you know how to work with pvc; by all means install it yourself. It'll be close to half what they quoted you.
    Jul 2013
    Long Island, NY
    14
    No problem bjsbuds! You are most welcome to join in.
    I did my PVC work this weekend. It might have been more work than an average install would entail because I basically re-did all the plumbing: I had some leaking joints and the equipment layout wasn't working for me. The only glich was I had to replace my multi-port valve: someone cemented in one of the fittings I wanted to replace. Not nice. I put in a Pentair dummy IC cell for now. I'm happy to report: it came out great and no leaks!
    I'll pull the trigger on buying the controller and actual cell this week. I'm more comfortable doing electrical work but it looks easy enough.
    Based on my experience so far, I'd say "go for it!
    May 2015
    102
    I found a Pentair IC40 with Intermatic Power supply for $724.00 w/free shipping on ebay. Purchased it two weeks ago and installed it last week. Working good so far.
