Results 1 to 7 of 7
Thread: Backyard Retreat - Nashville, TN
    kadx7006's Avatar
    Feb 2013
    Nashville, Tennessee
    6
    Cool Backyard Retreat - Nashville, TN
    We had this pool installed in May 2010. It was a package deal from a local pool store and came with what they called their "Saltwater Treatment System" which was actually a Copper treatment with a shock treatment done every two weeks. Pool maintenance by their guidelines (using their test strips) was fairly easy and I had sparkling clear water but I noticed toward the end of the summer I actually had bugs living in the water. I spoke with my pool store about it and they said "Oh, they will die off...don't worry about it". When it came time for winterizing the pool, I had to use "their" special winter chemicals and in the spring use "their" special startup chemicals plus by a new Copper Cell. Again during the summer I noticed I had bugs living in my pool and they appeared quite healthy.
    On a lark, I bought some standard test strips and found I didn't have any measurable amount of chlorine in my pool. The test strips "they" provided just tested for Copper, ph and alkalinity.
    It was in the winter of 2012 that I found Trouble Free Pool and it was through the "pool school" I discovered that "their" system didn't really sanitize the pool water, all it did was prevent algae.
    Thanks to trouble free pool, I weened my pool off the Copper treatment system and installed a saltwater generator. I went with the SWG because visited a friend of mine with a SWG and learned from him how easy it was to install and maintain his pool. I also purchased a good test kit so I could monitor and tweak my pool water as needed.
    Attached are pictures of our backyard retreat that gets lots of use by the whole family.
    24' x 54" Vinyl AGP,
    Hayward Aquatrol SWG, Xstream 150 Sq Ft - 1Hp Pump/Filter combo with dual returns,
    GLI 28' Whirlwind Solar Cover Reel System,
    Taylor K-2006-SALT Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Backyard Retreat - Nashville, TN
    It looks great!
    Congrats on taking control of your pool and your wallet!
    Divin Dave,
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Very nice, Do those heaters do anything noticeable?
    Lomart 18x48 AGP 7000Gal
    Hayward S210T w/Hayward 1hp Power-Flo Matrix Pump 2-Speed
    TF-100 w/Speedstir!
    Jul 2014
    Peoria, IL
    389
    Glad you found the forum and will get off of "their" program and on "your" program. Where you will know exactly what is going on and why. Looks like a nice setup.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    kadx7006's Avatar
    Feb 2013
    6
    Actually the heaters work pretty well...on a bright sunny day they would recover the 3-5 degree loss that occurred overnight. I just got the solar cover on yesterday and with it I'll gain 2-3 degrees net per day. Last year I would gain 3-5 degrees per day but one of the heaters developed a leak (of course right after the warranty expired) and I finished the season with just three.
    I was late getting the pool open this year so it looks like I won't need to spend the money for the 4th heater. I do get a bit of a drop in flow with just the three heaters but everything still gets adequate flow. By the way, they are all connected in parallel. The first time I installed the four of them, they were connected as two pair in series/parallel. I had to change it to all four in parallel because whenever I cut in the heaters, my SWG would trip on low flow.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    That is a heckuva nice set up ya'll have there! Good stuff!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Nice yard and setup!
