Results 1 to 16 of 16
Thread: cloudy blue pool
    May 2015
    Winfield Alabama
    31
    cloudy blue pool
    Hey guys I am new to opening the pool. I have test the pool and all levels seem fine here's a pic of what it looks like
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: cloudy blue pool
    Welcom fellow Alabamian! Before and one can help you'll need to post a complete set of t st results. What test kit are you using?
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    May 2015
    Winfield Alabama
    31
    for right now, I am using a regular aqua chem 6-way test strips. my results from the test are
    total hardness-250
    total chlorine-1
    free chlorine-0
    bromine-0
    pH-7.2
    total alkalinity-120
    stabilizer-50
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Your pool is cloudy because algae is growing in it. Algae is growing in it because there is not enough chlorine. Chlorine must be maintained above the minimum level for your CYA level at all times or algae will grow. Chlorine CYA Chart
    Get a good test kit from the Test Kit Comparison, I use the TF100 from tftestkits.net.
    Once you get your test kit you will need to SLAM Your Pool to kill the algae.
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP! If you follow the advice given and get a good test kit I promise your pool will look great!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Winfield Alabama
    31
    I don't understand how to do the Slam. Like I said this pool is all new to me. Before the pic was taken we had already added about 9 lbs of shock because we have been trying to open for 3 weeks.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    No worries. We are here to help you. Did you read through the link that pooldv posted for the SLAM? You can also read my SLAM process that is linked in my signature. It may help you get a better understanding.
    Lisa
    May 2015
    Winfield Alabama
    31
    I did. Thing is there is no pool store near me and I can't get a better test kit until I order one. Since I don't have a better test kit is there anything I can directly pour in to clear it up?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Unfortunately, you will have to order a test kit. You don't want to blindly add anything to the pool and make things worse.
    Lisa
    May 2015
    Winfield Alabama
    31
    Ok thank you so much for your help.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome. Post your numbers once you have a recommended test kit and we can get you rolling. I love my TF 100 and you get more bang for your buck with bigger bottles. I recommend the XL option and the speed stir too.
    Lisa
    May 2015
    Winfield Alabama
    31
    I think I have found out the cause of the cloudiness. The water is supposed to hit the top of the glass while filtering correct? Mine just has water to the glass and bubbles moving inside I have a pic but im not sure if you can tell or not.IMG_5429.jpg
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I cannot see the bubbles, but yes it water should be to the top. Do you have an air relief valve to release the air? Once released if it does it again you probably have some place that is sucking air.
    Lisa
    May 2015
    Winfield Alabama
    31
    The water is to the top just bubbles. Where would the air relief valve be?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Ok. I am not sure where your air relief valave would be. Mine is different and on top.
    Lisa
    DFW, TX
    24,450
    That cannot cause cloudy water. Cloudy water is almost always caused by chlorine levels being too low for the CYA level. It is also usually a sign of algae.
