Thread: leak
    May 2015
    valparaiso/in
    4
    leak
    I have a leak and I believe it is in the stairs. Is there a way of patching without draining the water or patching at all? Been told it's $2500 to replace the stairs, which I can't afford. About ready to be an ex-pool owner.
    Re: leak
    If you can locate the exact spot that is leaking and don't mind the patch being visible it is fairly easy to patch the steps.
    May 2015
    valparaiso/in
    4
    Re: leak
    Ok. Was wondering if under water repair kit might work on stairs.
