Thread: Adding chemicals
    Adding chemicals
    How much time in between application do I need to allow between bleach and muriatic acid? I'm assuming that they should not be added at the same time.
    Thanks so much. Your site is awesome. I am algae free for the first time in quite a while (and a much more informed pool owner!)
    14,000 gallon in ground pebbletech pool
    Purex Clean & Clear Plus 2hp pump - Hayward Navigator
    Test Kit TF-100
    Cave Creek, Arizona
    Oct 2007
    Philadelphia, PA
    Re: Adding chemicals
    I'm assuming you're adding chemicals in front of the return with the pump running. With good circulation, it takes anything added about 30 min to be well distributed in a typical pool. After about 10 min of circulation, whatever you added should be sufficiently dispersed to avoid unwanted reactions due to locally high concentrations.
    I would wait at least 10 min and 30 min if possible. If your circulation if poor, you should wait longer.
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    It would also be better to add them in the opposite order, acid first.
