Thread: First TF-100 test - New Pool
    Oct 2013
    Spring, TX
    87
    Our new pool was filled on 4/23, and the PB took care of maintaining the water until now.
    I received my TF-100 kit today. Here are my first test results:
    PH - 7.6
    FC - 2.5
    CC - 0
    TC - 2.5
    CH - 275
    TA - 100
    CYA - 20
    I'm planning on running the chlorinator with Trichlor tablets until my CYA raises to about 30, and then switch to liquid chlorine.
    I guess I also need to increase my chlorinator setting a bit to get a FC of 4.
    Any other suggestions?
    15k gallon IG, 36' x 15', built April 2015, Pebble Sheen
    Pentair CCP420 cartridge filter, Pentair EasyTouch 8 controller, Sta-Rite Max-E-Therm 400K Heater
    Sta-Rite IntelliPro VS pump, Sta-Rite Max-E-Pro 1HP & 2HP pumps
    Paramount PCC2000 ICS, TF-100 w/SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: First TF-100 test - New Pool
    Since you're in Texas and we will eventually get rid of the clouds and rain and the sun will make its way here, you might consider raising teh CYA a bit higher.
    At least 40 and 50 wouldnt hurt in the middle of summer.
    One we get into late spring and summer with blaring hot sunshine, you'll see a lot of fC burnoff at 30.
    However, having said that, if you pool gets a lot of shade during teh day, then 30 will likely be just fine.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    I think you've got it figured!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Looks good! Yes, need to bump up FC right now. Let's hope for some sun and chlorine burnoff soon!
    Here are my fave Pool School articles in case you missed them.
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Oct 2013
    Spring, TX
    87
    Thank you. FC is now at 3.5.
    I will retest my CYA next week to see how quickly the Trichlor tablets affect it.
    If there's no noticeable change, I'll add stabilizer in a sock and switch to liquid chlorine.
