Thread: swg issues
    swg issues
    Replaced the pcb on my mineral springs unit due to issues in the fall. After opening the pool and adding salt etc I turned on the swg to find a flashing no flow light. that goes out after several minute. Is this likely the flow sensor or another problem?
    Any help/idea are appreciated!
    Inground, 22k, vinyl, Hayward superpump, Progrid DE filter, Aqua heat pump, Mineral Springs SWG
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: swg issues
    It could be, but have you verified chlorine generation? Are your levels good?
    You can always "catch" water from a return using an upside down air filled container and see if the FC level of that water is different than the bulk water in the pool.
    Support the site
    Jun 2014
    Roseville, CA
    343
    Re: swg issues
    The low flow light should go out within a minute. It's designed to not let your cell have power until it has water flow to avoid damage to the cell. So Mine is no flow - steady light, then changes to a flashing light for a few seconds before it goes out, then begins to generate chlorine.
    So as suggested, if you are getting chlorine out of the pool return, your system is working.
    Posting your test results would be handy for further diagnosis...
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Re: swg issues
    Went back and checked the wiring diagram...board came configured for 240 volts and I have 120...moved the jumpers and have a fully operational unit now.
    May 2014
    Franklin, NC
    9,187
    Re: swg issues
    Quote Originally Posted by Greg111 View Post
    Great job!!
    Support the site
