Thread: New SWG Questions.
    New SWG Questions.
    Hello Everyone,
    Today, I installed a Pentair IC40 Salt Cell. I used Morton Pool Salt to get started. Is it OK to use solar salt going forward? I currently have the cell running at 80%. Is this the proper setting? Should I let my pump run overnight? How long will it take for my low salt light to disappear? When will it be Ok to swim in the pool?
    Thanks
    I live in the Albany NY area. The size of my pool is 24,000 gallons. The pool is an In-Ground rectangular Double Roman with a vinyl liner. I am using a Taylor K-2006 water testing kit. I have a DE filter. I have a regular chlorine pool. The pool cleaner is a 2017 Dolphin Premier Robotic In-Ground pool cleaner.
    Jun 2011
    Long Beach, CA
    2,784
    Re: New SWG Questions.
    How long has it been since you added the salt and what amount of salt in ppm did you aim for? If it has been less than 24 hours I would turn it down to 0% until tomorrow to let the salt mix in.
    Solar salt is fine, make sure it is 99%+ pure with no additives.
    Post the chem levels and we can suggest any tweaks from there.
    The SWG % is dependent of pump run time and how much chlorine is needed. Each pool is different and yours will need to be adjusted as you go along. Testing is required everyday for a little while until you get the settings dialed in.
    Fine to swim if chem levels are in range. You can swim while adding salt if you want.
