Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Please Help!
    May 2015
    New Milford, New Jersey
    68
    Please Help!
    Hi Everyone.
    I am hoping for some guidance; I just had my pool opened Wednesday, I cleaned it the past couple of days and then had the water tested (I did buy the recommended test kit but just this once brought it to pool store). My alkalinity was at 0--the pool store tried getting me to buy $70 worth of stuff but I did not-----I added baking soda using the pool calculator for amount;
    Questions
    Now my water is SUPER cloudy, is that normal for awhile?
    I used baking soda that is fresh burst, was that a mistake?
    When/how do I add bleach as my chlorine?
    Do you not use shock at all using the BBB method?
    I am feeling overwhelmed right now, appreciate any help/advice/guidance!
    Thank you!
    17x34 and ranges in depth from 3 ft to 6 ft.; I think 20-22 thousand Gallons
    IG -Vinyl with Waterfall
    Hayward Super Pump 1.5 HP
    Pentair DE 60 Filter
    Hayward H300 Heater; Taylor K-2006 Complete
    May 2015
    Wildorado Texas
    252
    Re: Please Help!
    Welcome to TFP, Adam!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    First, post a full set of test results before we start shouting suggestions. Is there any chlorine in the water? That would be my first priority but I do want to see the other readings.
    Support the site
    May 2015
    68
    Re: Please Help!
    Thanks!
    Free Chlorine- .07 ppm
    total Chlorine .19 ppm
    Combined .12 ppm
    ph 6.3
    Hardness 180 ppm
    Alkalinity 0
    Cyanuric Acid 109 ppm
    Copper .6 ppm
    Iron .3 ppm
    Borate 18 ppm
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    Quote Originally Posted by AdamS View Post
    Thanks!
    Combined .12 ppm
    ph 6.3
    Hardness 180 ppm
    Alkalinity 0
    Copper .6 ppm
    Iron .3 ppm
    Borate 18 ppm
    OK, those are the pool store numbers, what did you get with your test kit? We really don't trust pool store testing.
    Support the site
    May 2015
    68
    Re: Please Help!
    I didn't know that! I guess I wrongly assumed they were accurate, I didn't even test it myself--I have my kit, but can I test now after all the baking soda I put in or do I need to wait?
    LAST TIME I'M GOING TO POOL STORE!
    what should I do? I made a beautiful looking pool, super cloudy, aaaah! Ok thanks!
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    You would think they would be better, but unfortunately not. I trust your numbers having never done a test more than theirs.
    Yes, as long as the pump has been running go,ahead and break open that new test kit. Which one do you have?
    And the idea to stay away for. The pool store is a good one. We will teach you to save money by showing at WalMart and Lowes.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Please Help!
    Welcome Adam!
    Right away there is a huge gaping hole in those numbers. It is against the laws of physics to have 0 TA and 6.3 pH. Strictly impossible. One thing we teach is learn your testing, and trust your own results. Begin spending some time in pool school and start with the ABCs. Knowledge is the key and once you build some, this stuff is really easy.
    Essential Links:
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    Quote Originally Posted by Patrick_B View Post
    Welcome Adam!
    there you go, pointing out issues. But, is it the laws of physics or chemistry?
    Support the site
    May 2015
    68
    Re: Please Help!
    Oh my god, thanks guys. Ok I will test myself, I have the taylor k-2006 complete;
    I am assuming I put in too much baking soda, I know you will wait for my results but I will be able to fix that? Is there anything I need to go buy, I need to run out now if there is something;
    I have bleach, shock, borax already...thank you!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Please Help!
    Hold off on any more additions until we get some numbers. No worries, we can help line you out when you get some solid readings.
    Quote Originally Posted by tim5055 View Post
    Take your pick, they are a little tough to seperate, but it really depends on who you ask.
    Essential Links:
    May 2015
    68
    Re: Please Help!
    ok used my kit for first time, it wasnt bad and really regretting not doing this in first place!! Ok cant go back, hopefully you will help me going forward!
    Heres what I found:
    The free chlorine did not turn color at all!
    The PH was a dark purple, higher than 8 I'm thinking and I put a bunch of the acid test and it was not changing
    For the Alkanny it took 14 drops at that spot its 140--sound accurate?
    Calcium Hardness, 300;
    ok now what? Shock? Bleach?
    Thank you for your help!!
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    Step one, get the pH down. That takes muratic acid. I'd like to see 7.5
    Step two, chlorine - add some bleach
    Pool Math is your friend. Plug in your numbers and it will guide you to your additions.
    http://www.troublefreepool.com/calc.html
    in the future, it's easier on our eyes if you report your findings like this
    FC
    pH
    TA
    CH
    Support the site
    May 2015
    68
    Unhappy Re: Please Help!
    in the future, it's easier on our eyes if you report your findings lie this
    FC
    pH
    TA
    CH
    Ok thanks..quick questions:
    I will do the muratic acid, do I wait to do the bleach until the ph is down? Also, I have vinyl pool, muratic acid is safe, correct?
    Also, I think I inaccurately described it as cloudy, its more like soapy from too much baking soda (the fresh birst smell no less- I am so mad at myself!!), will this go away, should I drain some of the water first or just follow your steps?
    Thank you again, hope we get to use the pool this weekend
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    Well, I missed one thing, but so did you. What did the CYA test reveal for you. The pool store said 109 (nothing is that exact). But you didn't give me a number from your test. The CYA level is what controls how much FC you need to keep in the pool. So, tomorrow,when the sun is nice and bright do a CYA test. It works best when sunny.
    If if it is high, the. Yes you need to replace some water before you start worrying about other levels.
    Sorry I missed it.....
    Nothing we suggest will harm your liner if you follow the instructions. For most additions , pouring chemicals slowly in front of a return with the pump running will disperse the chemical so no damage will occur.
    Support the site
    May 2015
    68
    Re: Please Help!
    Well, I have added the muratic acid, will re-test everything in the morning, including cya.
    What level would cya be at for you to tell me to drain some water? how much water do you drain at one time?
    Feeling quite discouraged. Woke up this morning with crystal clear nice looking pool water; now it looks like soapy mess that I made!
    I hope I can fix this water and get 2nd chance, I am feeling much more comfortable with test kit!
    Thank you everyone for your help.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Please Help!
    We have fixed much worse pools than yours.
    Here are some of my fave Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Jul 2008
    Seacoast, NH
    253
    Re: Please Help!
    One sec...
    Are you sure you used baking soda? Googling Baking Soda Fresh Burst all I came up with was laundry detergent.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Apr 2015
    East Wenatchee WA
    39
    Re: Please Help!
    I agree with Deb. I've never heard of "fresh burst" baking soda. In fact I've never heard of anything added to the name of baking soda. And you keep saying "soapy mess". Did you add Arm and Hammer brand laundry something or another?
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
  20. Back To Top    #20
    May 2014
    Franklin, NC
    9,198
    Re: Please Help!
    Adam,
    check out the package, was it baking soda or detergent?
    Support the site
