Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Pool is Clear, please help me keep my pool clear
    Aug 2014
    Indianapolis, IN
    66
    https://mail.aol.com/webmail/getPart...s=IMG_2701.jpg
    FC 3
    CC 0
    pH 7.0
    TA 230
    CH 190
    CYA 0
    I know I have to add bleach, increase my pH and CYA which I want to do carefully because I have raised it too much last year. I think there may be a picture included. How much do I care about TA and CH?
    How long after adding borax can kids swim?
    Appreciate any advice.
    Michelle
    Michelle
    14K gal AG, installed July 2014, 1.5 HP Eco-Kleer sand filter, Aquabot Pool Rover Jr, Taylor K-2006 test kit
    Jun 2014
    15,283
    Re: Pool is Clear, please help me keep my pool clear
    Hi Michelle9! You are correct that some adjustment appears to be in order based on your test results. First & foremost - maintain your chlorine level so you don't lose that clear water. Also, get some stabilizer for your pool to protect the chlorine. I would suggest an initial target of about 30 for CYA. You can add it by placing the stabilizer in a sock and hanging it by your skimmer. It will slowly dissolve, but may take a few days before the readings adjust. Since you have 0 right now, you really need to watch your un-protected chlorine level. Your pH doesn't seem all that bad, maybe just increasing slightly, but the TA does seem quite high to me. Others may validate those concerns later as well. Your hardness (CH) is not too terribly bad right now. Focus on the chlorine and CYA for now, along with the TA. Keep using the TFP pool calculator and let it do the work for you.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    I would leave the pH alone and just point the return towards the surface. This will serve the purpose of raising your pH and lowering your TA at the same time.
    Don't worry about the 190 calcium level with a vinyl liner.
    After you hang the CYA sock, assume it's present in the water and add bleach for that level using Pool Math.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Agreed, aerate to increase PH. Kids can swim 30min after borax add.
    Most important is get CYA in the pool and keep FC level above the minimum for your CYA level at all times, Chlorine CYA Chart. Squeeze the sock a few times a day to speed up the process.
    Here are some of my fave Pool school articles in case you missed them
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add.
    Use PoolMath to figure out how much to add.
    Aug 2014
    Indianapolis, IN
    66
    Well, we have family coming for a party this weekend and so my husband added some soda ash trying to help. He had not been on board with pool math, the testing kit, and all the bleach buying. He had been to the pool store a bit and some of his work friends have had pools for years so he was getting information from them. Both the pool store and his work buddies had different advice than listed here, and I told him we should follow one line of advice, and I wanted to follow the advice on this website. So the pool care was up to me to use the methods listed here. I think he became a believer after I got the pool from black/green to clear blue. So I am glad he is on board with the pool math and just adding bleach to get keep the FC at the correct level. I am also happy he was trying to help with the pool using pool math, but now our pH was over corrected.
    This morning the water is cloudy and numbers are:
    FC 10 (we both added bleach yesterday)
    CC 0.5
    pH 8+ it was darker than the 8 on the vial.
    The kids did swim for the first time this year yesterday afternoon and had a great time. I look forward to a summer with lots of swimming
    Thank you for your help and wisdom, I appreciate all the advice and will re-read the above mentioned articles.
    Michelle
    Michelle
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Let the FC drop below 10 and retest the PH. A little muriatic acid will lower it back down quickly. I found it at Home Depot in the garden center for $2.99 a gallon, 31%
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If you already have CYA dissolving, the FC isn't too horribly high. As far as the ph, muriatic acid is pretty cheap, and extremely fast acting. You can knock it right back into line pretty quick.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2014
    Indianapolis, IN
    66
    I just added the muriatic acid. Will the kids be able to swim this afternoon, since I added the acid this early in the day?
    Thanks
    Michelle
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    You can safely swim about 30 minutes after acid addition. As always, make sure the water is circulating with any additions.
    Aug 2014
    Indianapolis, IN
    66
    Thanks, We always have the pool filter on.
    Michelle
    DFW, TX
    24,514
    Just to be clear that the PH test results are not accurate when the FC is above 10. Wait until it is below 10 to test/adjust PH.
    What is your CYA level? Cloudy water is usually a sign of low chlorine. It is very important to always keep your free chlorine above the minimum level for your CYA level on the Chlorine CYA Chart. Always like never below it, ever. When FC drops below the min algae starts to grow and clouds your water, then green, then swamp!
    DFW, TX
    24,514
    BTW, when you know you are going to have lots of people swimming you should add more chlorine ahead of time. Target halfway between target and shock level, or a little more. This will keep you from dropping below minimum on busy swim days. It is safe to swim as long as FC level is below shock level.
    Aug 2014
    Indianapolis, IN
    66
    OK, kids were swimming and
    CYA was 0 yesterday, stabilizer in sock, thought I read I need to wait a week before testing CYA again, kids just finished swimming and I just tested the pool, here are my levels
    FC 1
    CC 0.5
    pH 7.8,
    Added bleach and more muriatic acid.
    Good to know that we need to get FC up before more kids come swimming tomorrow. We will add more bleach.
    Michelle
    Aug 2014
    Indianapolis, IN
    66
    Just tested again:
    FC 4.5
    CC 0.5
    pH 7.6
    So I backwashed, added more bleach and put the robot in to clean. Will test again after a couple of hours
    Michelle
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Good job
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Did you use Pool Math to determine how much stabilizer (CYA) to add? What is your target CYA level?
    chiefwej
    DFW, TX
    24,514
    You need to add chlorine based on the assumed level of CYA you added to your pool. Based on the Chlorine CYA Chart
    Yes, wait a week for CYA to show on the test.
    Aug 2014
    Indianapolis, IN
    66
    Thanks to everyone for the advice.
    I do use pool math with every testing.
    Our target CYA 30, 56oz of stabilizer added per pool math.
    I was using the 30 on the CYA chart for our FC level. Since that is our goal I was using that with Pool Math, hope that is right.
    Just now:
    FC 12 added bleach to get it up near shock level since we will have lots of swimmers tomorrow
    CC 0.5
    Will recheck in the am.
    Michelle
    DFW, TX
    24,514
    That all sounds great! Good work.
    squeeze the sock several times per day to speed up the cya dissolving.
  20. Back To Top    #20
    Aug 2014
    Indianapolis, IN
    66
    Just tested again:
    FC 15
    CC 0.5
    Swimmers are not coming until late in the afternoon. Pool is looking more clear, but not like it was before adding the soda ash. But I am sure we will get back to crystal clear water soon.
    Thanks again for the advice and encouragement!
    Michelle
