Thread: Polaris - How important are leader hose floats?
    May 2014
    Pflugerville, TX
    148
    For whatever reason the PO or Pool installer removed all 4 floats from the leader hose on my Polaris 480. They didn't bother to leave them for me, but the unit is getting stuck on the steps a fair bit.
    Along with a torn debris bag and stiff swivels (there may only be one on the hose, I forget.. so that might have gotten removed too?) ... I'd rather spend a little to repair this rather than a lot for a new cleaner.
    Problem is the unit is 8 years old and I did the gearbox last year.
    Should I get 2 swivels, 4 floats and a new bag. Total is $80 + tax on Amazon.
    Then I also have to figure out why the wheels only rotate about 26RPM. May be a booster pump issue?
    I do have two spa jets that are being worked on, so the jets are currently removed meaning the orifice is spewing more water into the spa area. I don't know if this could account for the 7-10 "RPM" slowdown I'm seeing on the Polaris, though?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Polaris - How important are leader hose floats?
    The swivels need to be replaced periodically as they tend to get stiff with time. It may take some experimentation to get the right number of swivels and floats. Just be aware that too many floats can cause tangling.
    Here is a post you may find helpful: http://www.troublefreepool.com/threa...etting-tangled
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by BoDarville View Post
    Ok. So the number of floats provided isn't necessarily the number of floats needed. Nowhere in the Polaris manual is this mentioned.
    Now I need to figure out why I'm only running 26RPM.
