Thread: Hello from Michigan
    May 2015
    Northville
    6
    Hello from Michigan
    Good Day All-
    I hope you are great.
    Wanted to introduce myself, I am in SE Michigan and we have a 30k inground pool, we have had this for about 15 years and have seen a little bit of everything.
    I look forward to learning and sharing here.
    Best regards, Tony
    Casey's Avatar
    SW PA
    10,428
    Re: Hello from Michigan
    Welcome Tony!
    Jun 2014
    15,068
    15 years! Well then, you should have some great stories and advice for some of the TFP family in the future. Feel free to explore this site and customize your signature later. Have a great summer!
    Scottaustin26's Avatar
    May 2015
    Houston, TX
    32
    14.5K gallon IG plaster pool, 1K gallon spa, dual 2hp Jandy pumps, 60 sqft DE filter, 400K BTU NG heater. Dual waterfalls, Jandy Aquapure SWG, Polaris cleaner with 3/4 HP pump, Aqualink RS. See my pool here.
    Thanks!, Austin
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum Tony!
