Thread: input on cost
    cbrach411's Avatar
    May 2015
    Surprise, AZ
    108
    input on cost
    for our sheer waterfall/ raised area they gave me a break down of costs:
    10' of 16x16 travertine cap ( top of sheer) 27$ per foot= 270
    15' of stone on face& sides of raised area 15$ per ft = 225
    and then apparently they have to finish the back of the raised area which is called strip & finish 10 ft of this at 21 DOLLARS per ft = 210$
    this seems extremely expensive to just finish the back of the raised area like why wouldn't we just put stone on the back of as well since its CHEAPER?
    Thanks for any help anyone could provide.
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    Re: input on cost
    Quote Originally Posted by cbrach411 View Post
    The cap seems expensive to me, but that could be the standard price. I have over 100 feet of travertine cap on my retaining wall and a large flower bed area, and I did it myself in a day with no prior experience(although I did hire out the stone on the face of the walls). The travertine cost me 3.50 per foot to give you a guideline of what they're charging you for labor vs material cost. In my opinion, laying the cap is much easier then doing the face. There's really very little that can go wrong when you put the cap on, just make sure it's straight and level and move on to the next one right?
    The stackstone looks pretty reasonable. Your builder is probably getting the stone for around 3-5 per sq ft I'd guess --depending on what kind of connections he has. Honestly, the pricing doesn't look bad, except I have no idea what strip and finish means, I'd probably think of it the same way you do and just do the stone all the way around for 15 per ft which is quite reasonable. If you bought the stone yourself at a good price and hired out the labor, you probably wouldn't be too far from that price.
    13K Gallon IG Pool/Spa -- First time pool owners -- Completed in 2015 Caribbean Blue Pebble Tec Pentair 4000 Series 47 sq. ft. D.E. Filter Pentair IntelliFlo Variable Speed Pump Pentair SWG Jandy LXi Heater 400,000 BTU S.R. Smith Typhoon Slide Pentair LED 12v Lights Dolphin Nautilus Robotic Cleaner TF-100 Test Kit
    Our Build Thread
