Thread: Who tests the WC of propane at installation?
    4knights's Avatar
    NE Kansas
    419
    The propane company set the tank and ran the line ( in the trench I dug) to the heater. They are now going to get service truck to fill it. Who is supposed to actually adjust the regulator pressure to the correct WC per manual??
    Thanks
    Ron
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Who tests the WC of propane at installation?
    Assuming you are talking about the external propane tank regulator. The tank/line installer should do that. Most all propane appliances are designed to run within a set range of water column inches. In fact, most propane appliances have an internal regulator that will fine-tune the pressure coming from the tank, post-tank regulator.
    Also, in most locations, an inspection by the city may be required. They will focus primarily on doing a leak test but, depending on the municipality, they could also test line pressure.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    The people who come to fill the propane tank will usually run a leak test to make sure everything is good to go. They uses a solution of soapy water in a spray bottle and spray it at the connections.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
