Results 1 to 18 of 18
Thread: Opened the pool and first store test results very high Chlorine and CYA levels
    May 2015
    Macomb, MI
    14
    Complete pool newb here, but I'm quickly learning about the "joy" of pool ownership. We just opened the pool this week on Monday. Actually had the professional that put the pool in originally do it, as I knew nothing. Anyway, I took a water sample to the local store last night and here are my test results from the ClearCare Expert analysis. In short, they tell me I'm in chlorine lock and I need to drain 2 feet of water, refill, and check again. From what I'm reading around the interwebs, I'll more realistically need to drain over half the pool. Was hoping to get your input on the situation. Is it worth getting a second test done to verify things?
    Free Available Chlorine 16.67
    Total Chlorine 16.67
    Combined Chlorine 0
    pH Level 7.9
    Total Alkalinity (Input) 152
    Total Alkalinity (Adj) 99
    Calcium Hardness 147
    Cyanuric Acid 160
    Copper .1
    Iron .2
    Manganese 0
    Nitrates 0
    Total Dissolved Solids 1300
    Phosphates 1000
    Saturation Index .5
    Endure 19
    Thanks!
    16x32 IG Vinyl 22K gal, Tagelus Deluxe High Rate Sand Filter TA-60D, Jacuzzi Magnum Force 1MF-S pump, Hayward CL-200 Chlorine Feeder (NOT in use), Raypak RP 2100 Heater
    , K-2006 test kit
    Jun 2013
    Indiana
    57
    Re: Opened the pool and first store test results very high Chlorine and CYA levels
    Welcome.
    Chlorine lock is their code word for your CYA is too high. You need to get a test kit so you can get accurate results yourself, but yes you are going to need to drain some water and test again. How does the water look? You will need to keep your chlorine level high until you get your CYA lower. See pool math to calculate the appropriate levels.
    IG plaster, 22,000 gallon, Jacuzzi Laser Sand filter
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    when it comes to pool store testing, its always a good idea to get a second test done, but not by a pool store. if you poke around this forum you will see the m.o. is to do accurate testing yourself with a quality test kit, and add to the pool only what it needs, purchased cheaper from grocery or hardware stores, not overpriced, unnecessary products that the pool store says you need based on their inaccurate testing and seemingly lack of knowledge.
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Wanted to say welcome to TFP! As the others have said you need to get your own test kit and forget the pool store.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum,
    Chlorine lock is a myth, but it means what you, and the previous posters have said. Your Cya (stabilizer) is simply too high, if that reading is corect. If it is, you will need to drain and refill a bit more, but you won't really know until you get some reliable numbers from a proper kit. Your source of chlorine is what got your Cya too high, so you'll need to look at changing that, or you'll wind up in the same spot you're in now.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Welcome!
    The others have already covered test kit and drain, but in case you're wondering how that happened....
    Here's a little comparison I wrote a few weeks ago
    We'll take a 16000 gallon pool, because that's what I have. On a fresh fill, prominent national pool chain recommends 2.5 pounds pf stabilizer per 10,000 gallons, which works out nicely to 4 pounds which brings CYA to 30.
    With an average loss of 2 PPM/Day or 14 ppm/week, I'll have added 8.6 PPM/CYA if I used trichlor pucks perfectly. And they recommend a weekly "shock" of dichlor between 5 and 10 FC.... 2-3 oz per 10,000 gallons. Split the difference; I'll add 4 oz. CYA went up another .9.
    So..by the end of week one, I have added 9.5 more CYA. It is now 39.5. Mimimum FC for that is 3, so I'm probably okay.
    Week two, up to 49 CYA.
    Week three, 58.5. Minimum FC should be 5, but they recommend 3 as ideal, so the pool looks a bit hazy. So I'll toss in a little extra dichlor "shock" to jack FC up to 10. Which adds another 6.4 CYA. Keeping count? We're up to 64.9 now.
    That caught the algae just in time.. we had two weeks of good luck. A steady diet of pucks and 4 oz. "shock" each week only added another 19, up to 73.9 now.
    Week 6 it started looking funky, so we "shocked"it once again. CYA is up to 99.3. But minimum FC to keep algae at bay is 8, and we're still holding things to 3, because prominent national chain's preprinted sheet shows that as ideal. So algae got a toehold and the pool has a bit of a tint. So we throw two whole bags of dichlor in which jacks it another 7.6 by the time week 7 is over, we're at 116.4, because we had pucks in the floater the whole time.
    So...in 7 weeks, from 30 to 116.4. Let's say there are no more algae outbreaks because they sold me a huge bucket of phos-free and another of yellow-out monopersulfate "shock" Nothing but the pucks and the extra 4 oz of dichlor "shock" weekly. So the next 7 weeks added 66.5, which brings the total to 182.9 CYA.
    Now if we didn't understand this and things looked a bit hazy, we might throw an extra puck or two in the floater every couple weeks, which will drive it over 200 easily.
    Jun 2012
    Rochester, NY
    247
    Welcome!
    Yikes! Everyone should be required to read that to understand what those products do to your CYA. Great Posting!!!
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    May 2015
    Macomb, MI
    14
    Thanks everyone for all the quick feedback and the welcomes! The pool looks pretty good - maybe a little cloudy if anything, but color looks good to the untrained eye. Thanks for the information on "how that happened" Richard320. I was definitely wondering. The previous owner said he put 4-5 3" pucks a week and shocked it every other week. I will definitely be ordering a test kit today and go from there. Thanks for the handy links Patrick_B.
    , K-2006 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    These pucks get sold to everyone under the name of ease of pool management, none of that messy liquid Chlorine / Bleach, however you can see all the problems they cause, so ask yourself is the headache of handling a little bleach less than the long term headache those pucks cause?
    May 2015
    Macomb, MI
    14
    Ah, Isaac, I miss Louisiana! (Lived in Mandeville for a few years) - Yes, I'm glad I didn't buy the pucks that I was about to yesterday. I was going to order a K-2006 test kit, since I could get it quickly via Prime, but I see everyone endorses the TF-100 and I reviewed the comparison table. That's what I'm going with.
    , K-2006 test kit
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    OMG Richard I think that's the single most helpful thing I've ever read here (saying a lot) and explains so much of my trouble the last two years! THANK YOU!!!
    Ditched the pool store with the new start with our new pool last week and have come to LOVE the Pool Math section here, but the relationship of FC and CYA and the water was still a little hazy, if you will, until this post. Awesomeness on a stick.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    May 2015
    Macomb, MI
    14
    Crystal clear, but some high numbers - safe to swim?
    Noob pool owner. Pool was opened one week ago today. Only numbers I have so far are from pool store 4 days ago (self-test kit arrives Wednesday). Water is crystal clear. "Looks" beautiful. Based on these numbers from the pool store, is it safe to swim in?
    FC 16.67
    TC 16.67
    CC 0
    Ph 7.9
    TA 152 (99 adjusted)
    CH 147
    Cya 160
    Copper .1
    Iron .2
    Manganese 0
    Nitrates 0
    TDS 1300 (I think they just typed this in)
    Phosphates 1000
    Saturation Index .5
    Endure 19
    Thanks!
    , K-2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Crystal clear, but some high numbers - safe to swim?
    As long as they are correct , yes it's safe to swim, but you have your work curt out for you. That FC is very low for your CYA.
    Support the site
    May 2015
    Macomb, MI
    14
    Thanks for your super-fast reply Tim. I'll post back on Wednesday, when I have a chance to test it myself.
    , K-2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Letting FC drop below minimum for CYA level will allow algae to grow. Chlorine CYA Chart
    Yours needs to be above 12 at all times and really should be 18-20. You do not want to let algae grow because shock level would be 62ppm.
    May 2015
    Macomb, MI
    14
    I was able to test with the Taylor 2006 today.
    Cya 100+ (can't tell how high actually, because it only goes to 100)
    Ph 7.5
    FC 13.2
    CC 0
    TA 170
    From what I understand, I'm looking at partial drainage until I get Cya down.
    , K-2006 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, you likely want to do several partial drains until you get the CYA down to something more manageable
    May 2015
    Macomb, MI
    14
    Just came across an old Bioguard test the previous owners had done in 2012. On the sheet it says Cya ideal level "30-200"!
    , K-2006 test kit
