Thread: SWG- going away for weekend
    May 2015
    Monroe/NJ
    76
    So I just got my SWG up and running- see specs below. I haven't had a chance to play around long enough to figure out the optimal % to put the generator at to maintain chlorine. I know this is impossible to answer completely but anyone with experience with this type of generator can give me a ballpark % of what I should run it at if I have it running 12 hours/day? I'll be away until Monday evening and leaving tonight.
    Chlorine 5 (got to 5 by running at 70%) Ph 7 Hardness 220 alk 65 CYA 40-50 (guessing- was 34 early this week but added 6 pounds since then) salinity 3500
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,616
    Re: SWG- going away for weekend
    Looks to me like you're good to go if you're holding 5 FC the way it is now. You can fine tune when ya' get back. You can always dose it with some plain old bleach as well.
    May 2015
    Monroe/NJ
    76
    thanks- I became a bleach expert these past 2 weeks as there were all sorts of issues with my SWG!
    Heat Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    When I am leaving town and nervous about the SWG not being dialed in I leave it as it is and add bleach as a buffer. You can go up to shock level for your CYA, Chlorine CYA Chart. more FC is a lot better than not enough. (up to a point of course )
