Thread: Sand Filter Questions
    May 2015
    Ohio
    13
    I just put up a 24' round above ground that I bought used.. took it down and set up at my house,replaced liner and in process of filling now.I'm not sure how old sand is in filter(not sure how often if needs replaced)..I have filter that looks similar to the one being cleaned in the videos.I dont have the black cap that he shows putting on at beginning..not sure if previous owner took off and forgot to give to me,as the filter was unhooked and empty when we bought it.It does look like something is in drain hole (looks like some kinda plug with X on it)
    I haven't put water in it yet to see if it comes out there yet.If I do need to replace sand,how much do I need to get? #20 sand right?
    Allure52 24' round AGP 13,000g/sand filter/Intex SWG....Taylor K2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: Deep Cleaning a Sand Filter
    You do not need to replace your sand. Sand last forever. Here is a tutorial on how to deep clean a sand filter, pics and all!
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You need to post the make and model number of the filter to know. Different filters use different amounts of sand. Please post this as your own question instead of hijacking this thread about deep cleaning filters.
    Solar Blanket, Well Water, Borax Added. 68
