Thread: Low hung Liner
    May 2015
    toledo,ohio
    2
    Low hung Liner
    I have a polynesian kidney shape pool. Fiberglass sides with a low hung liner. The person who put in my last low hung liner told me that next time I would have to covert my liner to a full hung liner because 3m made a waterproof tape which was very expensive around 3 to 4 hundred dollars a roll. He said 3M has discontinued making this tape. Does any body out there know if this is true and if so is there any other adhesive tape that can be used to seal the liner after inserting in the track at the bottom. also is it possible to still have a low hung liner built and installed or do i have to go to a full hung liner route. What is the approximate cost in doing this?
    thanks hal
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Low hung Liner
    Welcome to the forum Hal!
    Someone will be along to help pretty soon on this. I'm no good on these liner questions sorry.
    Essential Links:
    Jun 2015
    Chaplin Connecticut
    3
    Re: Low hung Liner
    Having the same issue did you ever find help?
