Thread: 2nd year with pool, can't remember a couple of things
    georgiadawg's Avatar
    Jul 2014
    Eastanollee GA
    93
    When we set up the pool and fill it, do I go ahead and test the water after getting the salt in? Do I go ahead and add bleach after testing to get chlorine up since it takes a while to build it up with the SWS?
    Thanks.
    Lisa
    Northeast Georgia Pro Series above ground circular metal frame set pool 22' x 52". 11,400 gal capacity. w/ Skimmer plus 2000 pump/filter. Cartridge filter (Type C)
    Intex Krystal Clear Saltwater System Model CS8110
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: 2nd year with pool, can't remember a couple of things
    Yes. Yes. Don't forget to get some CYA to keep the sun from burning the chlorine off as fast. Use poolmath to verify the amount you need to add.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2014
    15,056
    If in doubt, you can always post your test results for us to review. We'll let you know if you're on track.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, you want to start out with a little FC to hold you over until you starts generating it on your own with the SWG. Once you are filled, go ahead and run a full set to see where you are, and if you post them as mentioned, we can help if you need it.
    Essential Links:
