Thread: New solar cover - reusing grommets?
    May 2015
    Abbotsford, BC
    17
    Just got a new solar cover, want to attach it to the existing Rocky Roller system (http://www.rockys.ca/grommet.html) but for the life of me, I can't figure out how to get the grommets apart. Any tips?
    "After a time, you may find that having is not so pleasing a thing, after all, as wanting. It is not logical, but it is often true."
    Pool: 80,000l (21,000 USG) 32'x'16' in-ground concrete with vinyl liner
    Re: New solar cover - reusing grommets?
    I use a large screwdriver to pry the two sides apart. Do it carefully, though. Put it in one side, twist it a bit to pry that side up a little, then spin the grommet around and do the same to the other side. Keep at it, and it will eventually pop apart. I've done this 16 times (8 grommets, twice), and I've only had one break on me.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    May 2015
    Abbotsford, BC
    17
    Thanks, will give it a go when I get home!
    May 2015
    Abbotsford, BC
    17
    So I made it even easier: found two large slot screwdrivers and slid one in on either side - pushed the grommets apart easy-peasy.
