Thread: Does this winter cover look okay
    First time with a pool and first time covering one. Is this cover to tight? Is it supposed to go straight down the side wall? Mine angles down probably 45 degrees from the sides and then angles down from the air pillows I have under it. I am worried about it pulling the sides in when it gets snow on it this winter. I had the next size bigger cover but it seemed way to big. Thanks
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Does this winter cover look okay
    Looks good to me. The air pillow will take the stress off the side walls. Spots that are next to a deck can be tough. Looks like you've got enough room to get a good hold in spite of that.
    Keep the water pumped off and you should be all set.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Looks good to me too.
    Thank you both, I am just trying to make sure I do everything right this winter.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    This is exactly what I did with my pool...I posted the idea but not pictures in the above ground pool section regarding my poorly fitting pool cover and 54 inch walls. It looks good to me...I was concerned that maybe the pillow looked a little over inflated...but too hard to tell from picture...I inflated my between 1/2 and 2/3 full. Just a bit of news...we have had winds gusting to 25 - 30 MPH this weekend, and the cover has held fine...and it beets the water pillows that you pay $7-10 bucks for a piece...I use milk and chlorine jugs...and i only put them every other section...I can put more out as needed, but right not it is fine...I have had it covered for the entire month. Every thing is good.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Feb 2008
    Northwest Indiana
    900
    We had 50+ mph wind gusts yesterday...pool cover held just fine...the water jugs work...I got a little bit of blowing under the cover but it never blew up like it used to before I put the water jugs on...
    Beave
