Thread: salt water control board out??
    May 2015
    Houston, Texas
    1
    My salt water control panel will light up when i turn it on and after a few minutes it goes off? i changed the fuse still nothing? the guy at the pool store said a common problem is a solder brakes and its an easy fix. any ideas??
    any thing will help? sorry im new here!
    Kelp
    Jul 2007
    Suwanee, GA
    528
    Re: salt water control board out??
    Hello Kelp and welcome to TFP. It would help to know the model of your SWG.
    I have seen PCBs with cold solder joints before on other appliances. To see if you do have that issue, you need to remove the circuit board from the panel and check the solder joints. You can slightly wiggle the larger components and see if the soldered side moves as well. If it does, you'll have to heat the joint, remove the old solder and then re-solder the component.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
