Re: Failure at Slamming?
Whether it is Ammonia or something else, you will have to keep pouring the Chlorine to it until you are able to hold and maintain a residual. You need not worry about the liner until the FC is higher than SLAM value for your Cya. It is FC that will bleach the liner, and it is only FC that can get you where you need to be. Even though you had MPS, it has the hall marks of Ammonia with the fast consumption of FC and very high CC, but FC is the answer. It may be a ton, but it the only thing that will get you where you need to be. You will have to add Chlorine until you are able to hold and maintain FC residual. Outside of drain and refill, this is what you will have to face. If you decide on a refill, take it in increments of thirds, until you replace the entire volume. I am not suggesting you must do this, but these are your only options sorry to say.
