Thread: Should salt turn water cloudy??
    Sep 2014
    Clarkston, MI
    30
    I have installed my Circupool Si-60 SWG, but haven't powered it up yet. I wanted to get the water balanced and warmed up first. Yesterday, with 63 degF water, I dumped 15 bags (600lbs) of Diamond Crystal blue solar salt into it. If I'm doing my Poolmath correctly, starting from 400ppm of salt, I should need about 900lbs of salt to get to 3500ppm. I wanted to creep up on the target rather than overshoot it, so I started with just 600lbs. I immediately noticed the returns turn a milky color as the dissolved salt started moving through the system. My water clouded over a lot and the salt took a lot longer to dissolve than I was expecting from reading posts here (a few hours rather than 30-60 minutes I was expecting). Annoyed with the delay, I turned my robot loose to suck it off the bottom and into the system (with the filter set to recirculate). After it all seemed to be dissolved, I switched back to normal filtering.
    Today, after 20 hours of filtering, the water is still a little cloudier than it was before adding salt. Is this a normal side effect of the salt in super cold water temps, or is there something else I should be concerned with?
    My only first-hand experience with a SWG pool is my neighbor's, which looked pretty crystal clear to me, so I'm assuming salt should have zero effect on water clarity. Correct?
    I didn't manage to get a test in tonight after work, but my results as of yesterday evening (prior to adding the final 3 bags of salt) were:
    Salt: 2800 (per the Taylor drop test kit, not strips)
    FC: 21.5
    CC: 0
    CH: 125
    TA: 180
    CYA: 70
    Prior to bumping up my FC, my PH was at 7.3~7.5. I raised the FC because the water seemed to have a greenish hue to it. Upon opening this past Saturday, I have had three 50% drain/refills to slowly get the CYA from 200+ down to a manageable level. I filled with well water, so it's possible the supply water has some iron in it causing the green tint.
    Any suggestions/guidance would be greatly welcomed. I've spent all winter reading about TFP methods (after buying this house late last winter and following the puck method the pool-stored previous owner had) and now I want to start the season off correctly.
    Rob
    ~35K gallon, 20x40 in-ground w/vinyl liner, slide/diving board, Circupool Si-60 SWG, Pentair Tagelus TA-50 sand filter, 1HP single speed pump, Pentair Minimax NT POS heater, TF-100XL w/speedstir
    Re: Should salt turn water cloudy??
    No that is not normal. Salt might cause a little local cloudiness right when you add it, but cloudiness that sticks around is very unusual.
    Your TA is a bit high. There is a remote chance that you had a little calcium clouding, but that seems unlikely. You can confirm if this is an issue by lower PH below 7.7, if it isn't below there already.
    Sep 2014
    Clarkston, MI
    30
    I didn't add any chlorine today, so I expect it will be below 10 tomorrow and I'll be able to get another PH reading.
    Also, I "fixed" (hot wired) my broken heater thermostat, so I'm actively warming up the water now.. maybe that will help.
    Sep 2014
    Clarkston, MI
    30
    24 hours later, with more mixing and water temp up to the low 70's, the water returned to crystal clear.
    I fired up my SWG for the first time and it seems to be doing something.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Sweet!
