I would lower PH closer to 7. Its cheap and quick. I too was tempted to Floc or Clarify, it is not needed. Just keep water moving and FC up, I went higher than minimum shock values, My shock level was 12, I went as high as 30 when I was trying to keep any FC in the pool and maintained 20 and let it drift down to 4-5 where I try to maintain it at now. I have a CYA of 30ish. I am not sure I can ever come up with a firm CYA number.
Edit: I was never able to maintain an FC level of 30, I would dose to 30 and after 30 minutes the test would read around 20, within an hour I would be near the MINIMUM shock level of 12.2. There are recommended levels for green algae and mustard Algae, but I have yet to see a clear standardized method to deal with CYA eating bacteria and the resulting ammonia. I never made a recommendation to take the same actions I did, but it was what I had to do in order to get ahead and now have a TFP. I also never let anyone in the water until it was clear and below shock level. Lowering PH helped a lot, and that was the recommendation I made.
My deep end took 5-6 days to clear up after my shallow end was clear. I have a 12 foot deep end.
Moderator comment: The recommendation to more than double the shock level is way outside teachings of TFP. FC that high could be very corrosive to pump equipment, especial the pump seals and it is probably unhealthy should you accidentally enter the water.
