Thread: New Z5 - not in the water yet - already a problem
    Jul 2010
    Double Oak, TX
    44
    I have unpacked and assembled the robot caddy. I started to remove the plastic protecting the scrubbers, when I found that one of the housing lids covering the filter does not latch. And I cannot adjust the latch to make it catch and hold the cover on. Has anyone else experienced this - new or after some use? Is this a minor annoyance, or will this impact running performance?
    Thanks for any advice.
    35K gallons, StaRite S8D110 DE Filter, Pentair IntelliFlo vs3050 pump, IG gunite
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New Z5 - not in the water yet - already a problem
    I have not seen that, but it will be a problem if it opens while running a cycle in the pool. I would see what I could to try and make it catch. With no fix, I'm not sure what to advise aside from calling the seller for resolution. Sorry to hear it, no similar trouble on my M5, but I think the lids/latches are the exact same ones.
    Essential Links:
    Jul 2010
    Double Oak, TX
    44
    I emailed & called Epic Pool Supply on this one. They were great. I ended up sending them video of the issue and we are in process of getting a replacement. What with holiday weekend and shipping times looks like almost 2 weeks before everything settles. I'd post the video here but it looks like only pictures are supported. So - hat tip to Epic Pool Supply for customer service.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Epic seems to have great Customer Service. Just curious... was it Cheryl you spoke to?
    Quote Originally Posted by dsm View Post
    Divin Dave,
    Jul 2010
    Double Oak, TX
    44
    Yes, Cheryl. She has been very helpful and pleasont to work with.
    Jul 2010
    Double Oak, TX
    44
    So - problem resolved. Had to return original unit to Maytronics. Some delay in getting shipping label as all of this started just before Memorial day. More delays due to work travel. Epic Pool Supply shipped a new replacement unit. I finally got my robot in the water this morning. I'll just say that I am very impressed and quite happy. Epic Pool (Cheryl) was great, and this Dolphin is one fine cleaner.
