Results 1 to 12 of 12
Thread: TA won't fall
    Jun 2013
    Southeast Pennsylvania
    125
    TA won't fall
    My TA was 110 and I wanted to get it down. I have put in a total of 16 cups of baking soda....two doses at 8 cups each over two days. Yet, my alkalinity seems to be the same. Here are my readings:
    FC 1
    CC .25
    CH 320
    PH 7.8
    CYA 55
    Pool just opened and first time this year lowering TA. Last year, I lowered it many times with these dosages. So, I don't get why it won't budge.
    13,500 Gallon Gunite Aggregate Finish, DE, SWG, 2.0 HP pump, 1.0 HP pump for 3 Sheer Descents
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TA won't fall
    You need to lower PH to 7-7.2 with MA which also lowers TA. Then let PH aerate back up. When PH is up to 7.8-8.2 then repeat until you have tour TA where you want it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    April's Avatar
    Apr 2014
    KY
    138
    Re: TA won't fall
    Baking Soda is used to RAISE TA.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TA won't fall
    Quote Originally Posted by April View Post
    Very good. I was going to come back and post that, but I got busy doing stuff.
    In addition to stopping the baking soda that raises the TA and using MA to lower instead. You need to get some chlorine in there.
    Lisa
    April's Avatar
    Apr 2014
    KY
    138
    Re: TA won't fall
    I had a little trouble keeping everything straight in my mind when I first started the bbb method. Had to keep reading pool school over and overt till it stuck.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TA won't fall
    You are learning well. Congrats!
    Lisa
    April's Avatar
    Apr 2014
    KY
    138
    Re: TA won't fall
    My pool is my baby. I love learning everything I can to make her sparkle. TFP has educated me well in the last 2 years. I don't post very often but I try to read everything I can to learn more!
    I may be addicted to TFP
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TA won't fall
    I am a TFP addict and I proudly admit it...lol
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: TA won't fall
    Helpful reading material links
    Lowering Total Alkalinity
    Recommended Pool Chemicals
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: TA won't fall
    Yep, it just sounds like a little refresher is in order. Back to Pool School for a little study time.
    Essential Links:
    Jun 2013
    125
    Re: TA won't fall
    OMG!!!!! I am screwing up royally in my second year. Yes, I need a refresher. Actually, my TA was going up as I added baking soda......now I know why.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: TA won't fall
    Quote Originally Posted by dubele View Post
    there are a lot of moving parts. Just take it slow and if you have to re-read before you add something there is no harm.
    Take a look AT&T eh article pooldv posted about lowering TA
    Support the site
