Results 1 to 17 of 17
Thread: Cant reduce High pH level
    Feb 2012
    Memphis, TN
    52
    So I've been trying to reduce my pH level if 8.0 by pouring in the amount of muratic acid the pool calculator suggests. For some reason, the level will not drop. Can my testing agent be bad?
    11,000 gal Fiberglass IG, Jacuzzi sand filter, Pentair Superflo 1.5hp 2speed pump, Hayward AQR15, Maytronics Active20, K-2006 kit, K1766, SpeedStir
    Feb 2012
    Memphis, TN
    52
    Re: Cant reduce High pH level
    Test results are
    Fc 5
    Cc 0
    TA 110
    CH 180
    PH 8.0
    Cya 35
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You will just have to repeat the process. Double check your your numbers in pool math and make sure they are all plugged in correctly and you have MA set to correct percentage.
    How old is are you PH drops?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    When I question my test kit, I usually run a test off of tap water to see what kind of readings I get. Granted I don't know exactly what I should expect out of my tap water, but usually see enough change to know my kit is ok.
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    Feb 2012
    Memphis, TN
    52
    PH drops about 3yrs old. Reason why I question it.
    I've checked every time and it shows the same results. I'll check tap water ph and see what it says. Thanks scon36
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    The drops may be bad then.
    Lisa
    Feb 2012
    Memphis, TN
    52
    So I tested the tap water and it's showing about 7.0 is that about right? Drops can still be bad?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    If that is the highest the PH test reads your PH could be much higher.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Feb 2012
    Memphis, TN
    52
    8.0 is the highest. You're saying it's probably way over 8.0?
    30,432
    I think the R-0004 drops you are using are fine and you simply need to add more acid.
    That said, three years is too long and I suggest you upgrade all your chemistry that is three years old. It is penny wise and pound foolish to chase pool chemistry with very questionable reagents.
    EDIT: and, yes, aimee is right. Your pH can be higher than 8.0 which would explain the additional acid.
    Feb 2012
    Memphis, TN
    52
    Sweet I'll try that.
    And yes that's one of few that haven't been used up since I bought the kit. Its been really stable at 7.6 for 2 years. I used a lot of pucks to raise the cya so could that be the reason why pH rises so much?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Yes it could be way over 8 which is why your additions of chemicals (MA?) don't seem to be bringing it down. If it were me I would keep making adjustments per pool math, let circulate for a while repeat test and repeat with chemical adjustments.
    On the drops being bad, I can't comment but I do know on that test you could be way over 8 if that is the highest it reads.
    Feb 2012
    Memphis, TN
    52
    How soon can I retest pH after adding ma? 15min?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Somebody may have a better answer than me on this but I'd want to know it had had time to circulate. I think I'd wait in the 30 minute to an hour range.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    AimeeH has it right on it could be much higher than 8. Keep adding per pool math until it comes into range. 15 min should be good, MA integrates quickly.
    Here is some extra info an adding Recommended Pool Chemicals
    Feb 2012
    Memphis, TN
    52
    Thank you all for your help! Put 8.2 in the calculator and added what it suggested. Its now sitting at 7.6. Perfect
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Happy dance.
