Results 1 to 12 of 12
Thread: Chlorine too high
    May 2015
    Santa Fe/Tx
    4
    Chlorine too high
    CHLORINE TOO HIGH! My pool is 2 yrs old this month. I had an above ground pool for 13 yrs...no problem with in-line chlorinator/hard piped PVC +Nature 2. I couldn't keep enough chlorine in it. This in-ground pool is a different puppy! I can't get the chlorine level to go down! Beautiful. blue water, crystal clear, LOVE it...but these are my latest levels:
    FAC=8
    TAC=8
    CH=99
    CYA=99
    TA-120
    PH=7.2
    COPPER=0
    IRON=0
    PHOSPHATES=100
    TEMP=75
    It has rained so much here in the last 6 months, that we drain water off the pool sometimes 3 times a week. I take my water to be tested, I add acid when needed, brush the pool weekly, run the cleaner weekly, I am a very hands on pool person...I don't understand the chlorine level in this pool. I do not shock it! The levels are too high. Just this week, I have had an outbreak of yellow algae....my first one in 2 years! I put yellow out in it, hoping that would bring the level down & kill the algae...didn't work on the chlorine! I know some of y'all don't like the chlorine tabs...what about using those Silk tabs? Help!!!
    in-ground 35.5 x 21=@ 24,705 gal.
    White mini pebble finish/tile/stacked flagstone wall/brick coping
    2 x 27" water bowls/10' Jacuzzi bench/w 1.5 hp. pump
    2.0 hp. pool pump/w a Zodiac/Jandy single element cartridge filter
    Fusion/nature 2 inline chlorinator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Chlorine too high
    Welcome!
    Your chlorine is not too high. Check the FC/CYA chart. If CYA is really where they say, you're barely above minimum, which is why you have algae. That's point one.
    Point two: "99" is pool store shorthand for "off the scale." Your CYA level is probably well over 100. When I took over my pool five years ago, I was at about 240 CYA. And guess what - the pool store wrote 99 on the sheet.
    Rain is good. Grab as much as you can and dilute that water to lower the CYA.
    I'll let others hammer on you about getting your own test kit, losing the Nature2, and SLAMming the pool.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Hammering that stuff Richard is skipping, high CYA is usually caused by overuse of trichlor pucks this leads to people spending lots and lots of money at pool stores then ending up here where we point out the underlying cause were all those trichlor pucks the pool stores pushed on them in the first place under the guise of easy pool management.
    The answer to this CYA build up cycle is to switch to liquid chlorine / bleach or invest in an SWG (salt water chlorine generator) all solid forms of chlorine will add either CYA or CH, both can cause problems at elevated levels.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Slam time and we need real numbers and a real kit. Get a Taylor or one of the great kits here....the link is in my signature.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    OP's pool is blue and Crystal clear. All numbers look good other than high CYA. I see no reason to SLAM. I do agree OP needs a good test kit.
    Oops, I missed the yellow algae part at the bottom. Sorry
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Santa Fe/Tx
    4
    I am assuming SLAMming is shocking it? Do you want me to use the packets of shock? I don't mind using a liquid...just have never used it & don't know how much to use. I do have a test kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    May 2015
    Santa Fe/Tx
    4
    I have a Taylor Deluxe poolcare DPD test kit...tests free & total chlorine or bromine, pH, acid demand, & total alkalinity. What do I need to by in addition to that? Is the only way to lower the CYA....by draining & adding water? I have well water. You would think with as much rain that we have had, it would have brought that down.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Unfortunately partial drains and refills is the only way to lower the CYA.
    Lisa
    Donldson's Avatar
    NW Ohio
    2,881
    Quote Originally Posted by dingram9 View Post
    This is an OK kit, but it is missing two key tests that you will need. DPD tests can only measure up to 5 ppm FC, and not entirely accurately at that. To complete the kit you will need to add an FAS-DPD test. It is able to measure up to 50 ppm FC and CC with up to a 0.2 ppm accuracy.
    It also lacks a Calcium Hardness test, which you will want to keep an eye on since you have a pebble finish.
    TFtestkits.net carries the individual FAS-DPD test: HERE, but you may want to look at the TF-50 since it will contain both that and the CH test.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    18,967
    Here is what you need to turn the DPD test kit into the FAS-DPD test kit.
    In a very few parts of the country, reverse osmosis treatment is available. It returns basically distilled water to the pool. I don't think it's available in Texas. There's also a new product called Bio-Active that's supposed to break down CYA. There have been a bunch of threads on it. Sadly, draining and refilling is still usually the most cost-effective method of lowering CYA. If you're getting a bunch of rain, grab as much as you can. I set it up so one of my raingutter downspouts empties into the pool, so I get 3X as much water as I would get without it.
    May 2015
    Santa Fe/Tx
    4
    Thanks so much for your time. I'll let you know how everything turns out
