Results 1 to 13 of 13
Thread: Hello all the way from Kuwait
    Adsonic's Avatar
    May 2015
    Kuwait
    34
    Hello everyone, just jumped aboard last night. I am a complete newbie, guess have to start somewhere and mine was the kids pool, a small 1550gal vinyl pool. I made sure though to buy the sand filter and SWG, the shop said it was over kill, but I went and bought them. After all, those are kids who will be playing in it (can't go cheap on kids).
    Just wanted to thank everyone for their help on my post, you're the best, and I thought it would be appropriate to say it here
    Abdulla
    Jun 2014
    15,228
    Re: Hello all the way from Kuwait
    This just reminds us what a small world this can be. I spent a few months in Saudi myself. Hope the area is treating you well. Always good to hear that TFP has made a positive impact on another pool owner. Don't forget to add a customized signature in the future with all of your pool info. Post some pics one day as well. Take care.
    Orlando, FL
    690
    Welcome! The sand filter is worth every penny.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Welcome, I think you will find doing it right to start with will make life easier all around.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Hi, welcome to TFP!
    Here is info on updating your signature, What we need to know to answer your questions
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Adsonic's Avatar
    May 2015
    Kuwait
    34
    Thanks for the worm welcome, you're sure are the best.
    Adsonic's Avatar
    May 2015
    Kuwait
    34
    Quote Originally Posted by pooldv View Post
    Hi, welcome to TFP!
    Thanks for the heads up, just finished doing it.
    1883gal Intex AG rectangular vinyl pool (only filled just below the water jet to avoid water sitting calm until all is well balanced, maybe 1600gal).
    Sand filter and SWG (not turned on yet). Taylor K-2006 water test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Wow, we don't see many from there that's for sure! Welcome to TFP!
    Essential Links:
    Aug 2014
    Seminole, FL
    92
    Quote Originally Posted by Adsonic View Post
    CYA zero? I'd be getting some CYA in there and some chlorine asap otherwise you may be facing a SLAM. Hazy water is not a good sign!
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Casey's Avatar
    SW PA
    10,457
    Welcome to TFP
    Adsonic's Avatar
    May 2015
    Kuwait
    34
    Quote Originally Posted by mikech View Post
    Yes you're right, working on increasing my CAY levels.
    Thanks for the welcome .....
