Results 1 to 8 of 8
Thread: Floating skimmer baskets
    May 2015
    Granger, IA
    3
    Ok....it's always bothered me a little bit but not so much that I worried much about it. I have 2 skimmer baskets that float out of their correct position -- Is this because of my pool having a SWG? Any suggestions on how to keep them seated properly without introducing an unwanted object in my pool water? It's my first question so go easy on me.
    18 X 36 Rectangle Vinyl - Hayward 1 1/2 HP Super Pump - Zodiac DuoClear 25 Chlorinator - 300# Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Floating skimmer baskets
    The easiest thing to do is to put a rock in the basket. Make sure the rock is too big to go into the actual port at the bottom of the skimmer though.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    my skimmer basket started floating after putting a skimmer sock on (after the pump turns off).
    just put a big rock in as John said.
    Dolphin E10 Cleaning Robot.
    Dec 2014
    Riverside California
    482
    +1 on the rock.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    May 2015
    Granger, IA
    3
    Thanks for the info !!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I agree with the rock. I have one in mine all the time.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Clarksville
    146
    Thanks for this info. Mine floats out with my pump on.
    vinyl soft sided pool
    intex 1500 gph sand filter and intex swg at 1500 gph.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Oddly mine is solidly pool down into position when the pump is on (as it should be) but once the pump off it bobs up some. Nothing bad happens, nothing falls out.
    I also use skimmer socks (well, Skippy does as he's got the work of changing them out and cleaning the baskets while I look on admiringly)
    Yippee
